Sanding thin walled bowls
Woody in VT
>Hello folks, I turn thin walled bowls. When I sand them, I end up with a raised ridge on the inside at the rim of the bowl. Any ideas on why that happens and suggestions for fixing or avoiding this problem? As always, thanks in advance.
Re: Sanding thin walled bowls
Barry Elder
>You don't say whether you power sand while the lathe is running, hand sand on or off the lathe, but I'll hazard a guess that the bowl is flexing and needs firm support on the backside of where the sander makes contact.
Bruce McElhaney, Spring Lake, Michigan
>I'm not exactly sure what you mean by raised edge. Hopefully you're using good sanding technique. Barry is probaly right about the flexing. I also do thin wall bowls and find a bowl steady to be very helpful for both finish cuts and sanding on the inside. If you don't have a steady rest you could use a light steady touch with a gloved hand on the outside of the bowl when doing final work on the inside. Personally I find that technique slightly beyond my comfort zone, but know several turners who do it safely.
Mike Jones, Redding, CA
>Jimmy Clewes teaches a method. The inside and outside of the bowl are cut to finished thickness, sanded, and sealed, progressively from the rim down, an inch or so at a time, rather than turning the entire piece then going back to sand in a separate step. This prevents flexing and uneven wall thickness.
Also, you might be trying to remove too much with abrasives. It is challenging to cut thin (and evenly) with the gouge, but worth mastering.
robo hippy
>I am not sure about the raised ridge either. Is it there before you start to sand? If so, it is cutting related, not sanding related. As far as using your hand for a stead rest, on a thin bowl especially (less than 1/8 inch) I would sand at slowest speed possible which for me is about 10 rpm. I don't think it will make any difference if you are turning green or dry wood. I would also use the soft pads, not the stiff ones, and only grits 180 and above. Any lower and you can go through the bowl. DAMHIKT Ever see the Del Stubbs video where he has a piece of green apple on the lathe that is about 1/16 thick and has water on it while turning very slowly, using his hand on the outside to steady, and has a scraper at a shear angle on the inside? Food for thought.
robo hippy
Fog Tanner
>I turn some thin walled bowls as well. I do use my hand on the outside to prevent chatter when cutting, scraping, and sanding. I don't use a glove as a lot of times the outside is finsihed and I don't want to scratch the surface with leather. I learned how to do this in a class with Raffan, and it just takes practice. And he is right, if your hand gets hot you are pushing too hard with the tool.
On occasion I have problems with portions of the wood sanding away faster than others or some interesting shape I am doing. After watching Clay Foster several years ago, I have taken to using a goose neck cabinet scraper for working some of what you describe. I generally use this with the lathe running at a slower speed, or on some offcenter peices with the lathe stopped.
Mitchell Cholewinski
>Woody
I am curious, what do you call thin walled. I like to do this myself. I posted a ne bowl up above that is 3/32" thick, almost completely translucent. Did all the sanding by hand. Mitchell
