Sharpening the new HannesTool Bowl Gouge
Donna Banfield
>A while back there was a posting about the new bowl gouge by JoHannes Michelsen, HannesTool. It uses the same tool steel that Doug Thompson uses (Doug supplies Hannes), and has an ergonomic grip that is very comfortable to hold.
At around that time, I just finished shooting video for expertvillage.com, on how to make a twice turned bowl for this website. In the video, I use the HannesTool gouges to turn the bowls, and show how to sharpen the tool, which is done freehand.
The video is now going online, and the clips on how to sharpen the HannesTool gouges are in these 3 clips:
http://www.expertvillage.com/video/121124_using-woodturning-tools-hannes-gouge.htm
http://www.expertvillage.com/video/121125_sharpening-woodturning-tools-hannes-gouge.htm
http://www.expertvillage.com/video/121126_grinding-woodturning-tools-hannes-gouge.htm
I don't know if Hannes will be at the AAW Symposium this weekend; he is a Powermatic Distributor, so he might be there with them. But if you get a chance, you should try out the tool. I don't get portion of every tool he sells, or anything like that. I just find it, and this grind, easy to use, and not just for turning hats.
