Grizzly bandsaw and drill press
steve p
>New turner just getting started. Looking at Grizzly 19" bandsaw and drill press, any feed back on this company? Thanks Steve Ponch
steve p
Why do you need a drill press as a turner?
steve antonucci
>As a new turner, the three things I wouldn't be without are:
a lathe (duh!)
something to sharpen with (I own a Tormek, and you couldn't pry it from my cold dead hands...)
and a chainsaw (free wood is everywhere)
If I expanded it to other nice to have's:
A chuck
Compressed air (for blowing out hollowforms and dust)
I rarely use my bandsaw since I work in wet, round wood. I've yet to find a blade that works well and fits my saw (Rikon 18"). Occasionally, I'll run something through it just to not have the smell of gasoline on me. Chainsaws are a lot more useful and much cheaper than a bandsaw, and don't take up nearly the floor space...
Steven
P.S. Unless you are going to make pens, you don't need a drill press as a turner. You can drill on the lathe too...
Re: Why do you need a drill press as a turner?
steve p
>Steve, I took two one week lessons to get me started. One with wet wood, and the other with staved and cured woods. I lean toward the dry wood. I like the results and the way it cuts. In several operations in dryed woods we used both bandsaw and drill press.
Re: Grizzly bandsaw and drill press
>The 19" Grizzly is a resaw bandsaw. It has a very large capacity (12" in height and ~19" throat depth) and a large motor. It may be a bit large. The 17" is smaller but has the same height.
I've used the 14" Grizzly bandsaws - they are good off shore knockoffs of the Delta 14". I've used the Grizzly cabinet saws and they are good. I haven't used the large drill presses, only the smaller bench top radial drill press. The radial works fine.
Gary in Zirconia,NC
>Steve,
I have the 17" Grizzly. I really like it and for the price it's great. I wish I would have got the 19" though. It has a larger table which is very valuable when cutting large green wood. My saw will cut 12" oak with no trouble. Don't waste your money on Grizzly blades though. Get Timber Wolf blades. They have ones just made for green wood and are excellent.
Gary
Dick Hines
>I have a "BIG" drill press that belonged to my grandfather and use all the time. I also use my Jet bandsaw with a riser block almost every day.
Now my table saw is another thing. It has a piece of plywood laying on the table. Makes a good work bench.
Dick Hines
>Oh , forgot. I have a high speed grinder that is close to 50 years old. I spend less time sharpining with that and more time turning. The Tormek is to slow for my taste. Give me a Wolverine system and a high speed grinder and it's zip-zip and I am back to work.
You are faster, I get sharper :-)
steve antonucci
>The extra second it takes me I save with sanding becasue my tools are sharper. I forget who did the Scanning Electon Microscope study here a few years ago, but they had data to back up that claim.
15 seconds- Zip, zip, but no sparks, grinder dust or hot steel in the process.
Steve
All of the guys who were in my shop a few weeks ago that owned high speed grinders wished they had Tormeks when they left....Sharp beats fast in my book...
Check the blade length
steve antonucci
>I bought the Rikon, and it's a great saw for the price, but it's an odd blade length. The only place I can get blades is Woodcraft (which is where I bought the saw).
I'm still lost what you'd do with a drill press though? I have a small cheap Crapsman that isn't even connected to power most days. When I made pens, I'd drill them, and the only thing that used to bug me was how much quill travel I had (wasn't enough for any pen blank, so I drilled in sections...)
Steve
Re: Check the blade length
steve p
>Thanks Steve, without you guys I would be lost. Steve P
Dennis Yoder
>Steve, Suffok makes each blade to order so the Rickon length would not be a problem for them. For some reason my Jet with riser takes a 104.5" to have easy tensioning. Dennis Y
I agree on Tormek sharp. nm
Atwerz
I have a grizzly bandsaw
Dennis Taylor
>and I really have had no problem with it, mine has the riser blocks and it takes a 105in blade, which is readily available from local & online....I thought I would only use it for rough out of bowls and such, but I use it all the time, probably more so than my tablesaw...but I make carving rough outs and bandsaw boxes with it, many uses and I have had mine about 4-5 years now, easy to assemble and delivered to my door...I was VERY apprehensive about ordering something so large & $$$$ online, but no problems at all, delivered to local dealer for me, picked up slide off truck and took about 1 hour to clean & assemble and then more time to set up blade, but for turning it was good....if you are only using it for turning, you could go with a local lesser price really!
Dennis
