Stave Bowl Construction
RPE
>This may be too big of a question.
I want to make a segmented bowl with a combination of stave and normal segment rings. The center stave construction will be the "feature" ring. I want to make a zig-zag pattern using stave construction. Loyd Johnson calls it a "First Generation" pattern. If I get the "first generation" (zig-zag pattern) glued up flat, how do I cut it up to form the staves? I just can't picture it in my mind how to make equal width sides so the pattern will match up and go around the bowl.
I assume the stave segment joints are at the points of the zig-zag pattern. If that is the case, you have to bisect the points exactally or the pattern will never work.
Thanks.
RP
RP
