Coffee Mug Liners?? Where??
Ed Larson
>I need some sources for the coffee mug liners. My daughter is comeing out in Aug. and I need to make a mug for her.
Re: Coffee Mug Liners?? Where??
Re: Coffee Mug Liners?? Where?? *LINK*
ratts
>try this:
http://www.smoothturning.com/
eaglesc
>Woodcraft also has them
Price is a little higher but they also have a quantity discount on fewer units.
Woodcraft mugs
Woodcraft
Ralph
>I strongly suspect that Woodcraft is buying them in bulk from Smoothturning.
Smoothturning also offers bulk rates
My experience/conclusion
Mike Jones, Redding, CA
>I bought 3 of the stainless steel liners from smoothturnings and found the service and shipping etc. to be excellent. My end product, however, when turned thin and slender, offered little to no insulation and the coffee went cold quickly. When turned thicker, while improving insulation a bit, no longer would fit the small hand of my missus. It became a very "manly" thing, while offering less insulation than the cheap double wall plastic travel mugs.
Another consideration, any travel mug without a handle requires a driver to find the sip-hole each time a sip is taken and could easily distract that driver.
My mug gets a lot of comments, but to do another one, I think that I will buy an off-the-shelf, with-a-handle mug, and simply repace the outer wall with turned wood.
Hope this helps some....
Re: My experience/conclusion
DD
>Is there such a thing as an insulated liner available? That would cure the cold coffee issue?
Doug
Re: Woodcraft
ratts
>you might try using a foaming glue like gorella glue -- provides a bit of insulation and filles any voids.
