>I have made many chairs but all had square legs. I now need to make some chairs with round legs. The problem I need help with is the back legs have a curve to them. How is this done? Is the proper, easiest way to steam bend after turning? Thanks for the help.
>I think most of them are bent after they are turned.
OTOH, Norm turned some after they were bent. He sawed out blanks that had the bend in them and then made a "box" they fit into that was Vee or Y shaped so that one side of the Y had the leg in it and the other side had a counter weight. Chucked it on the lathe and turned the leg of the Y. Made a different box for the other end (maybe) and did the other part of the leg. Then faired the middle together with hand tools.
It worked for him, but it seems like a good way to die to me.
It is easier to work with green lumber for steam bending. Kiln drying usually sets the lignin and makes steam bending difficult at best. Trouble is, when you turn green lumber and dry it, it usually goes somewhat out of round. Not too oval, but I've had some pieces that differed by 1/4" (1 7/8" and 2 1/8") or more. For green lumber I usually steam at about 1 hour for 1" of thickness.
Air dried lumber can sometimes be steam bent reasonably well - just takes more steaming.
Different woods have different bending properties - so watch your bending radius. Pick a reasonably straight grained wood without knots or major grain swirls.
Have a good bending form made up of sturdy material and clamp it to a heavy bench. I use both wedges and clamps on my forms.
I have not bent legs after turning. I usually bend hoops, loops, backs and crests. I have bent cane also. I usually use my drawknives and spokeshaves to shape my pieces before bending.
While some may bend them after turning, they can be turned without any bending. This requires a little experience, good technique, a medium-to large lathe, and great care.
If the curve is cut from plank stock, you can make wedges from the wood that has been cut away, and attach these one at a time to the leg blank with band clamps. Then it is a simple matter to turn between centers after carefully aligning the turning axis, with one end contacting the wedge instead of the turning. When one section is complete, the other wedge is attached, and the other part of the leg is turned.
You need to be very careful to only work on the part that is directly in line with the lathe axis, and be very careful of the spinning "bent" part. For more details, seek out Jon Siegel at www.bigtreetools.com
