Hollowing with Kelton Scrapers
GolfSteve in Calgary
>This is my first foray into hollowing. I decided to go with the Kelton scrapers because they received some good reviews and their simplicity appealed to me.
I did pretty good hollowing out the vase - about 12" deep x 8" max. diameter. My problem is trying to remove the "cone" that is left on the inside of the bottom of the vessel. The Kelton instructions simply say to push the tool into the cone, tilt the tool 10-15� "into" the cut, and with repeated passes remove the cone.
Easily said. Much more difficult to do. Either my tool wouldn't cut or it would catch and knock the vase of alignment.
First of all, I'm not sure which way 10-15�C in the direction of the cut is. I would read that to be rotating the tool clockwise a bit. Also, it is best to use the straight scraper or one of the bent scrapers for this?
Any tips from the knowledgeable people out there? I got so many catches trying to remove than darn cone that I just gave up.
Cheers,
Steven
Re: Hollowing with Kelton Scrapers
James McClure
>I'll assume that you are not using a hollowing rig of some sort based on your description. So you must be hand holding the bars.
You definitely should use a straight cutter. Don't use the bent one in the center. David Ellsworth's video on hollowing has a very good segment about how to remove the cone in the bottom. I would recommend it. Basically, you want to find the center of the cone with the tip of the tool, then drop it slightly and then move it back up to the center and then across to the left. Find the center again. Drop it down, come back up, move to the left. Move it back to center. Drop it down, come back up, move to the left. Repeat this as many times as it takes to remove the cone.
12" deep on your first hollowing attempt is quite an undertaking. Are you using the 3/4" bars?
Exactly what James just said works great
My suggestion
Mike Jones, Redding, CA
>Chuck up a piese of scrap (preferable the same king as your workpiece)and make a cup in it about the same size as the bottom of your vase and leave the cone. Now play with it. Use the suggestions as above. Also, insert the cutter straight on, and rotate it counterclockwise, or sneak up on it well left of the cone and move your cutter slowly across the cone with the tool rotated clockwise.
After you do this a couple of times on the scrap, and right next to the tool rest, you'll at least know what you are trying to do when you get deep again. Hope this helps!
Good idea. Thanks
Re: Hollowing with Kelton Scrapers *LINK*
>Thanks James. I'm still having trouble visualizing this, but I will go home and try it out.
Sounds like you:
1) find the centre of the cone
2) angle the tip down a bit
3) bring tip up to the centreline again
4) move the gouge to the left
5) repeat ad nauseum or until catch occurs
BTW, 12" is the ultimate depth I want to get to...I only got down about 8-9" before I started having trouble with the cone. I am using the medium sized set of Kelton scrapers, which I think are the 5/8" shaft.
Kelton Hollowers
Re: My suggestion
>That's exactly how I use the Hunter tool to get rid of the nipple. I rotate it clockwise and move the tool to the left. I ride the bevel of the tool across to the right cutting the cone out of the center.
James McClure
>Yes, your summary is correct. The other suggestions are good as well. Especially the suggestion to practice on an open bowl with the tool rest far away. That will allow you to see what you are doing much more easily. Good luck!
robo hippy
>It is easier to drill out the center first, and there are extenders for doing this. Some even remove the center point of the forstner bit. As far as removing the center cone, If you have turned bowls, you have probably done this. I use a scraper and move it up and down, and side to side. If you can find the Dave Ellsworth video, watch it. You can take an end grain piece of wood, chuck it up, and play around with removing the center. A shear cut, with the cutter angled is less catchy than a cut with the cutter flat. It takes a bit to get the hang of it, but is doable. Inside of a hollow form, you can't see, so have to feel your way around. If your blade gets under the cone, it will grab, and come up on the other side. This can be exciting to say the least, and destroy the form. Of course, I learned this the hard way.
robo hippy
