ADVERTISE HERE - FREE TRIAL
Foam pads
Foam pads
Foam pads
ILYA ZAVORIN
>Phil Brown gave me a couple of these pads yesterday, and I used one of them to apply salad bowl finish. Phil got a whole box of them but could not remember off the top of his head where. Does anyone know a good supplier of such pads? Thanks.
Re: Foam pads
Re: Foam pads
Barry Elder
>Most hardware, paint, or homecenters sell them. Very common.
Re: Foam pads
Re: Foam pads
Rich Egan
>The cheap ones will sometimes break down and leave little black crumbs in your finish, but they are inexpensive and handy to use and just throw away.
Re: Foam pads
There are two types
Pete in Holland, MI
>The better type has the foam adhered to the plastic blade within the foam pad. The cheaper ones do not and don't perform well.
The better ones are usually the loose ones available by the piece. The sets come from another manufacturer/process and I don't like them.
I do use them almost excluseively in my shop for paint & varnish application.
Re: Foam pads
Re: Source
>In general, I've found that the ones sold in good paint stores are properly glued with adhesive that is resistant to solvents and can even be cleaned and reused at least twice; price .50 each; hint, the "blade stiffener" is larger and fully enclosed in the foam. The variety sold at the Borgs are only fair, and will break down or come unglued. The stuff sold on-line in packages is usually pure junk. I did the HF buy once; threw them away after trying two from the pack.
Re: Foam pads
Another Source...
jwoodwright
>I buy them from Michaels. Was in with my wife and they had a great selection. Worked well and have a 3/8" wood dowel handle!
I save the handles for other projects.
Removing the foam applicator, allows you to use the plastic stiffener and wood handle as a glue spreader... John K.
Re: Foam pads
Re: Foam pads
>I buy them at the hardware store and use them daily. Best thing I've ever found to put fly repellent on horses' faces, especially around the eyes.
