PM3520 Spindle/Pully Problem
Jerry Hall
>I have noticed noise in my pully system over the last few weeks. Cleaned everything out, dressed the belts. The belts often wandered a bit off the lower pulley but I was clueless as to why.
Today in the low speed range I suddenly got a grinding sound. Thought it was bearings, but as the picture shows the upper set of pulleys looks like it has slid to the left. You see the set screw embossing on the pulley key. The Allan screws were loose. This would seem to pretty well explain it.
Mechanically disadvantaged as I am, and before doing something totally ignorant I thought I would ask for some Wood Central wisdom on my diagnosis, and a repair. Should I just loosen the Allan screws and try to lever the upper pulley into alignment with a big screwdriver? Should I use some loc-tite on the screws? Or just check it regularly?
Thanks!
Re: PM3520 Spindle/Pully Problem
robo hippy
>Take the belt tension off, loosen the set screw, slide it into place, tighten everything back up, and turn again. It may need to be checked regularly. I did this without thinking because I changed the speed ranges a lot.
robo hippy
Keith Tompkins
Keith Tompkins
>HI Jerry, I would remove the set-screw, and check that its tip is in good shape, not all rounded over. A sharp rim helps keep it tight. If you loosen the belt, the pulley should move easily with a slight bit of wiggling. Heavy prying of the pulley may distort it, a vibration may result along with rapid belt wear. I would use loctite ONLY as a last resort; it will make removal for repair very difficult.
Checking items such as set screws is normal maintenance, read your owner's manual for other items that require service. All lathes require periodic maintenance.
What they said :)
Dave Peebles Lyons, Ohio!
>Hi Jerry,
There is also a LOCTITE that is reversable. The stuff I have used is in a stick like a chap stick. It is called "QUICKSTIX 248"
I picked it up at my local Fastenal store.
Best wishes,
Dave
Dick Hines
Re: What they said :)
Dick Hines
>If you use Loctite use the blue not the red.
Cyril Griesbach
>Jerry,
I had a similar experience with my 3520 and WMH Tech support told me just what others have said here. Get your self a 7mm T Handle allen wrench to make things easier.
Dennis Yoder
>Another method of securing the set screw is to install a second set screw over the first. Dennis Y
More ideas than I can shake my 3/4" bowl gouge at
Jerry Hall
>Life is good, my dirty old mustard monster runs SMOOTH. Thanks!
FYI or others, I used a 3/4" x 3" wide stick of alder and a rubber mallet levered against the housing to "ease" the upper pully to the end of the burnished mark on the shaft. I rotated the shaft periodically so it wouldn't jam. It took some steady firm whacking and didn't go easily. I found that I had to fine tune the location within maybe 1/32" for the belt to run absolutely true across the pullies and stay between the pulley shoulders.
Dennis, neat idea on the additional set screws. There is plenty of thread depth to accommodate them. Robo, I will check regularly, especially at the first sign of a sneeze or cough, and read the maintenance procedures.
Re: More ideas than I can shake my 3/4" bowl gouge
Dennis Yoder
>Jerry, they also make a setscrew that has a small nylon insert that helps prevent backout. They will come out then you want without any trouble. Dennis Y
