>I get a lot of vibration when I am coring bowls out of 14 inch plus blanks. Lots of rumbling from the General 260. I am using a Stronghold with #3 jaws. The McNaughton standard system is new and I have touched up the cutting edge; very sharp. Another turner is saying I should try the BIG tower jaws that Oneway makes for the Stronghold chuck. He says the tower jaws will grip better and cut down the vibration. What do you think? How do you mount your big bowls on the lathe? Do you get much vibration when coring? ET
>As a general rule, the further away from the headstock you mount, the more vibration you'll have. When coring I use my v120 with DT jaws with as wide a spigot as they'll take.
Try spraying your knife with some WD-40 or PAM. Are your knives ground to a center (spear) point or a single skew point? My set's older and I've reground mine to the spear which seems a bit smoother in the cutting.
Don't forget to back your knife out and clear the kerf which will smooth things out as well.
>I do a lot of coring, and I prefer the McNaughton. I use the big Vicmark, and a recess (2 5/8 inch wide). This works for bowls up to about 18 inches, which is in the maximum range for coring with either the Oneway, or the McNaughton. At 18 inches, it is getting a little vibration. If you use a recess, you want the fit of the recess to be as close as possible to the size of the jaws. Also, a dove tail holds better than straight jaws. Bigger chucks hold better than smaller chucks. It is a leverage thing. With a tenon, it is pretty much the same thing. You want the jaws to fit closely: if the chuck jaws close to 4 inches, you want a tenon 4 1/4 or so wide, and you want the tenon and jaw profiles to match. The foot/tenon should also be about 1/3 the diameter of the bowl, so if you have a 12 inch bowl, you want a tenon about 4 inches wide. You can get away with a bit less, but not much. If you are using extended jaws, this can also add to the problem, longer lever = more vibration.
Beyond this, some times it is the wood. If you are coring a really hard and dry wood, you will get more chattering and vibration than you will when you are coring softer green woods. Osage and locust are hard and chattery, the fruit woods core like butter. Deeper bowls will vibrate more than shallower bowls, again, a leverage thing. With the harder woods, just reduce your feed rate, go lightly. With the softer woods, I actualy use considerable pressure to push the cutter in faster, the wood will take it, and so can my lathe.
You will also probably notice more vibration when you finish turn the inside of the bigger bowls. The inside mass has been reduced, and and the walls will be more flimsy, so go gently, and you can use your hand on the outside to dampen the vibration.
