It will happen every time
Dick Hines
>I cleaned the 3 ft. pile of shavings out from under my lathe yesterday. With in 15 minuets my bowl gouge roled off the lathe and on to the concret floor. Go fiugure.
Dick Hines
Re: It will happen every time
Gary Evans Tallassee, TN
>And have you noticed when you drop something sharp on a concrete floor it always lands on the tip?
Gary
And if it is something small.........
Jesper, Denmark
>You can never find it in the shavings pile.
Carole Valentine
>That's precisely why I have anti-fatigue mats in front of, under and behind my lathe! They are for saving my tools as much as saving my feet.
Brian Hahn in SW Wisconsin
>That's why I have a wood floor and hexagonal flats on my tool handles.
make one of these
>Bummer. In addition to the rubber mats, that's one reason I built this little tray a few years ago.
Slips on the lathe bed in front or behind the tailstock. The top is covered with a piece of thin carpet. The block on the bottom fits loosely in the slot but can't possibly "lever" out. Keeps tools currently in use handy and protected.
Re: make one of these
Dick Hines
>I use a Kelton handle on my gouges. Looks like it would hit the floor first. Bugt s*** happens. That is why I have a grinder close at hand.
All sharp things will fall with the sharp end down. It's a law of nature.
Don't sweat it
wilbur
>Don't sweat it. That was your gouges way of telling you it needed sharpening. :@)
Richard Jones
>I made one almost exactly like JKJ's, but drilled a hole in the block to take the pin on my Jet 1642, at the end of the ways. Don't always use it, but it's nice to be able to lock the little table down if I want to.
I used a couple of old mouse pads on top of mine.
Dick, you should know better than to clean up........... :)
Rich
Lan Brady
>lol,
I cannot believe you lived long enough to be grey headed and not have learned this fact!
You are either hard headed or just dont believe cow horns will hook!
Thanks for the laugh, Lan
Re: All examples of O'Tool's Law!
Jamie Donaldson
Dick Hines
>Lan, I don't care what color my hair is as long as there is lots of it up there.
Have not heard back from Barbar yet.
georgetroy
>What would have happened if you had sandals on and you tried to catch it before it dropped? Ouch!
