Carving Tools for Turning
Tom Henderson, Gulf Breeze, FL.
>I would like some recommendations for selecting a set of carving tools to be used on turnings. Are there any good books on this subject? Thanks for any ideas.
The sky is the limit
James McClure
>If it cuts wood, then there's probably someone out there using it. Dremels, Foredoms, Dental handpieces, carving gouges... It kind of depends on what you want to accomplish in the end.
You should come to our woodturning club meetings. The club meets on the third Saturday of the month at the Woodman of the World Lodge at 9050 Ashland Ave, just off of 9 Mile Rd. in Pensacola. The next meeting is June 21st (but I won't be there). Here's the link to the club's website: http://www.artisticwoodturners.com/
Hope to see you at a meeting!
Re: Carving Tools for Turning
>Tom it really depends on what you want to do. I started my carving with nothing but a 3/8" woodworking chisel and a cabinetmakers rasp. Then my dad gave me a small set of General brand palm carving tools. I did a lot with those and still use them a great deal.
Then I purchased a dremel with varying bits and still use that for the start or fine tuning almost every carving. The trick to using the dremel, flex shaft, or small air carvers, are the bits. buy good quality carving bits from a carving supply house.
I now have several flex shaft machines, a small collection of carving chisels, many files and rasps, drum sanders, flap sanders etc. You can never have too much, "BUT" you can do so much with just simple tools.
Tell us what you think you want to carve and we'll try to offer some better tool choices.
Re: Carving Tools for Turning *LINK*
HeatherA in AK
>There is a good book on the subject by Chris Pye, Carving on Turnings.
Heather
Carving on Turnings
Re: The sky is the limit
>Thanks James: I was a member for awhile, but Ivan and the distance from Gulf Breeze just overtook me.
>Thanks John. I turn mostly bowls and hollowforms. I would like to be able to add some carving to the exterior of these. There is such a bewildering variety of carving tools available that it is hard to figure out where to start.
One of the responses suggested a book by Chris Pye, but it seems to be out of print.
Re: 2 good links
>Thanks Ron, those links do provide some good help
>Thanks Heather. I will try to find a copy.
>CHris Pye's book is good but too hard to digest. There is a book called Carving on turnings that is pretty good. I did all of my first fluting and spirals on bowls and hollow vessels with nothing but the Cabinet makers rasp.
John Jordan, who does a lot of that sort of thing uses the reciprocating carver, I can't remember the brand but it's pretty expensive. I use the Ryobi but you can't get them anymore and they vibrate too much. An inbetween priced unit is the Foredom flex shaft machine with the reciprocating handpiece. Buy a small set of Flexcut carving tools to go with it. This gives you the advantage of having both rotary and reciprocating carving tools. The foredom is a little expensive but you can use it for all sorts of carving and even sanding. I sand the fluted vessels with a 3"long x 1" diameter sanding drum in m foredom handpiece. I also have various other sizes of drums and flap wheels etc. These work great for cleaning up any carving.
Re: 2 good links
Don Orr
>Great info Ron. I saw the carving project over on FWW, but somehow missed all the tool info. Thanks for the links.
