Mini-Hollow Form
Mini-Hollow Form
Mini-Hollow Form
Ron McKinley
>Cherry with ebonized Box Elder Collar. About 3" x 3" with 3/8" hole in collar. Critiques welcome......Ron
Re: Mini-Hollow Form
charlie belden
>Put it back on the lathe and make the transtion from bottom to top smoother - or make the break very obvious and clear cut. But what I'm seeing it two pieces - which individually are nice - which were put together because on fit the other.
That's the fun and games of pieces with two or three components - integrating the parts into a coherent whole that looks like everything should be there - just the way they are. Cindy Drozda is a master at it.
charlie belden
Steven Antonucci
Agree with Charlie...
steve antonucci
>It looks like you had a great curve going, but ran out of wood at the top. The bottom also kind of flattens out, and I would have liked to have seen the foot follow the curve from the side down to a much smoother transition.
On a positive note, you've done a great job with the finish on the cherry. Looks like just about a perfect balance between shine and thickness...
Steven
Re: Critiques
Ron McKinley
>Thanks to both of you for your comments and I agree.....Ron
