THE WOODRAT IS BACK!
red elm?
red elm?
red elm?
Carol - now in NC Nebraska
>The neighbor is splitting red elm firewood. Tree felled two days ago. I was looking for some handle stock, so I grabbed a couple of pieces. No pith. Very straight grain. Looks to be stringy stuff. Very wet.
Thought I would clean off the bark and split into handle billets. Then rough turn round, wrap in plastic cling wrap and haul home to Arizona in a couple of months. Maybe wax it first?
Other thoughts are welcome. I like it to dry with out further splitting. Any thoughts about heartwood vs. sap wood? Dispose of the sap wood? Keep it? Good color contrast, not that that is important. :)
Re: red elm?
Re: red elm?
>Slippery Elm is sometimes called Red Elm. If you have that, it can be beautiful.
The sap wood on the piece I got was much lighter and in contrast with the darker heartwood. The heartwood was a lovely color with good figure. I made a natural edged bowl, turning it while sopping green. The spongy soft layer under the bark shrunk a lot more than everything else over the next few weeks but it stayed together nicely and the shrunken layer provided for an interesting band of surface texture.
Sorry, I don't have any experience with drying it first.
PS, did you ever make something from the piece of cocobolo?
Re: red elm?
Re: red elm?
Ace Foster
>Splitting elm by hand is a real good way to work up a sweat!
It turns pretty well, doesn't look bad, not a lot of figure, usually, not terribly prone to checking, but not immune, either.
Should make good handles.
Ace
Re: red elm?
Re: red elm?
>Not yet, John. While I am in Nebraska I have very little time to turn. I am just taking advantage of an opportunity to collect some of this wood to try some drying. I'm beginning with firewood, and if I end with firewood, I'll still have the experience! :)
Re: red elm?
Re: red elm?
>Charlie has a huge log splitter - homemade! He has no trouble splitting dripping wet wood. He'll burn it next winter. He splits for three houses to use to supplement gas (expensive!) heat.
Re: red elm?
Re: red elm?
Steven Kubien
>It is stringy, dries easily (minimal checking or distortion) in my experience and has some really nice colour and grain patterns. Sharp tools are an absolute must for the finishing cuts because tearout is really hard to sand out. Also, be careful how you sand it. There is great difference between the early and late in terms of hardness. I've done a few red elm bowls and if you are not careful, the surface you end up will be wavy. I discovered this by accident and tend to sand with a heavy hand to accentuate this because I like it.
Here is a lousy pic of a bowl I finished back in March.
Steve
Re: red elm?
Re: red elm?
Nick
>Carol-
I've worked with red elm some and I agree with Steven's comments about stability and sanding but it's not a very hard wood and won't make the best tool handles, I think. Depends on the type of tool, I guess. The best way to keep it from checking while drying is to seal the ends with paint or a green-wood sealer like Anchorseal.
