first hollow form
first hollow form
first hollow form
Steven Kubien
>Afternoon everyone,
This is my first hollow form. It started its life destined to be a calabash-style bowl but I kept rounding it, liked it, and decided to hollow it. I made a crude hollowing tool with a 3/16" cutter and something which resembled a handle and had at it. Scared the h*ll out of me and I quickly ended up with a Jamieson captured rig. Still, it was a good experience. I just don't wear those shorts anymore.
Ash, 6" x 3" or so. No finish and likely won't get one because it feels too good in the hands as it is. I called it Worry Stone because anyone who has played with it just keeps rolling it over in their hands, like a worry stone.
Thanks,
Steve Kubien
Re: first hollow form
Steven Antonucci
As a hollow turner...
steve antonucci
>Looks pretty good for a first one! My first forms have long been exploited for their BTU value.
I think I see a tool mark in the middle of the form. The good news is that you can probably turn a cone center and remount this to refine the sanding. Finish on small forms makes a huge difference.
Steven
Um, Steve
>I think he said it was finished and was accepted into the show as is.
m
VERRRRRY Strange
>This is the piece that got in the show as Steve linked to in his "I Got In" thread below.
That is correct, right Steve K? 'Cause otherwise there's some strange ---- happening here.
hmmmmmmmmmm
Re: VERRRRRY Strange
Steven Kubien
>I opted not to put any finish on the bowl/hollowform so that's why I say it's not finished. It is complete, in my mind, because I like it the way it sits right now. It 'could' be sanded further (it's at 320 or 400). It 'could' receive some wax or something (but it won't). Weird what the jury was looking for and I will be interested to hear their comments (and those of visitors to the gallery) at the opening of the exhibit.
Thanks,
Steve Kubien
Texture
>Steve,
If you get a chance, try lightly sand blasting a piece, followed by water to raise the grain a bit, then 1 or 2 applications of 1/2lb (very thin) super blond dewaxed shellac. Have done several like that and the wood can come out feeling much like suede. Neat surface but somewhat fragile.
mm
Re: Texture
Steven Kubien
>Thanks Mark. I have seen a few pieces in ash which have been sandblasted and I have wanted to try it out. What I didn't know was what to do after the blasting, but now I have something to try!
Do I need a special exhaust booth for sandblasting? What sort of compressor requirements am i looking at?
Cheers,
Steve
Re: Air +
>Hi Steve,
For what I'm doing, I just do it outside with (no booth) with one of those el cheapo Harbor Freight $9.95 top-cup blasters. You do have to were gloves, long sleeves, and a full face shield. You also need to stay well away from the car(s) and other things you don't want frosted.
While I have a medium size compressor (3hp/60gal/12 CFM), you can run a small gun like this easily with a 4-5 CFM compressor, even if you have to stop to let it catch up.
If, however, you're thinking of going to the kind of stuff Pascal and others do with the piece blasted into an open lattice-work, you'll need a cabinet and filters and such to control the dust and conserve blast media. Smaller cabinet should run less than $200 (which will have a gun feed built in) if you have the space for it, but you'll likely need a bigger compressor.
Re: Air +
Steven Kubien
>Thanks Mark. It goes on the to-do list for now, but perhaps a little higher on the list since I don't NEED any big, special equipment.
Cheers,
Steve
