Wolverine Grinding Jig Instructions
Ed Larson
>The Wolverine Grinding Jig instructions say to set the center line of the grinding wheel 6.25 to 6.5 inches above the platform that the base will sit on. Many articles (Kirk DeHeer write up in Winter 2006 AAW journal, eg.) on sharpening say the grinding wheel center line should be 6.25 to 6.5 inches from the top of the v on the Wolverine base. Our club is planning a meeting on sharpening where we will have three sharpening stations so they all need to be consistant. My sharpening system is set per the Wolverine instructions others are not.
Whats the consensus out there?? Bottom of base or top of V??
Re: Wolverine Grinding Jig Instructions
E.T.
>Bottom of base. I use the Wolverine on a 6 inch grinder and on a 8 inch grinder and have used the distance the instructions say to use. I had to raise the 6 in. grinder one inch and the Wolverine base 3/4 inch (I think) on the 8 in. grinder to get the 6.5 inch height. I have seen turners having problems with their "systems" and grinders because they did not follow directions. problems like having a tool jamming between the v-arm and the grinding wheel and resulting in the destruction of wheel. ET
Gordon Seto
>Actually, it doesn't matter. The wheel is round; the grinding surface is always tangent to the wheel. The height is for the clearance when you swing the side grind jig so the jig won't hit the wheel guard.
I can't take credit for discovering this. Kevin of Oneway explained this.
The Ellsworth jig is fussy about the wheel height because unlike the Varigrind, the material of the bottom front of the jig is not removed.
Gordon
Don Evans
>If their instructions have NOT changed since day one, then the first you stated sounds right. I only say it like that because of the difficulty of terminology used.
Setting the 6.25 to 6.5 using the top of the V is NOT correct.
The measurement should be made from the bottom of the assembly that the "V" arm rides in, up to the center axle of the grinding wheels.
I made mine using a cast iron grinder stand with a wooden laminated top, the top being mounted UNDER the small top of the cast iron stand, this made everything much easier to mount the wolverine as a 2x4 laid on it's side (1 1/2" thick) was a perfect shim for the "V" arm base to sit one. Measurement came out exactly half way between 6.25 and 6.5".
This stand sets on the base of my old Delta dust collector and is sucking air through both sides of it and blowing outdoors. NO, the bags are NOT on it for obvious reasons, only pipe from grinder to outside. On the end of the outside pipe is a special plastic (heavy duty) cloths dryer vent which I liked so much I put one on the house for the dryer. This is the one that has the can looking device on top of the hose that lifts up when air is moving and comes back down when turned off so pipe is sealed against insects rodents etc. I paid $50.00 for each then found same exact one for $20.00 this sites normal price, isn't it always the way? If you're interested in the vent, go to http://www.sportys.com, it's item number 3985T, sometimes you have to call them as the numbers cannot be found searching. I've ordered couple of times from them and no prolems so far. I have NO affiliation with these folks in anyway other than custormer.
Anyone want a snap shot of grinder set up let me know and I'll put one or two on here.
Don
GolfSteve in Calgary
>Hi Don,
Sounds interesting. I'd like to see pictures. Dust collection on a grinder is something I'd like to improve on. I hate getting that dust all over the shop.
Cheers,
Steven
Dust Collection at the Grinder
Peter Teubel
>Here's what I designed for my grinder:
Re:Now that's slick Peter! Did the ....
Jamie Donaldson
>...grinder come with the collection ports built in?
Re: Sparks
Ron McKinley
>Are the sparks from the wheels "dead" by the time they reach the vac? If so, I'm going to rig up something like that. Thanks for the idea....Ron
Peter Teubel
>Yes. One an always cut holes if there are none and affix a fitting for a hose/pipe.
Re: Sparks (actually DUST)
Peter Teubel
>I don't really care. There's nothing in the vac that can catch fire from a few sparks.
The vac is really meant to catch the stone dust when truing/dressing the wheels. I have a saying in my shop: If it falls the the ground, it ain't dust. I am only concerned with the material that can float in the air. Anything else is vacuumed up with the my central shop vac.
Don Evans
>That's what I did, cut holes. In fact mine are 4" pipe with no reduction.
I'll get a couple of pictures up as requested in day or two.
Don
Re:Dust collector & Grinder
Don Evans
>Next 4 post will be the pictures promised of my grinder with dust collector. First is an overall from right side. Second is close up and note the wood top is mounted below the cast iron stand top (gray), this is important in order for a 2x4 to work as a correct thickness for the wolverine jig.
Third is picture of outside vent, if not familiar with these they have a cylinder inside that lifts and closes back down when the collector is blowing then turned off. The air is directed downward as the top is completely closed off.
Don
Don Evans
Don Evans
Don Evans
>Here's one more showing the inside pipe going through the wall, note I turned a wooden collar to act as a molding for the hole.
