My off-center chuck
My off-center chuck
My off-center chuck
keith zimmerman, Normal IL
>By popular demand, here are some photos of the off-center chuck I designed and a member of my club put together. It is basically a screwchuck mounted on a scroll chuck that has a slot on onside that allows me to shift the center of a bowl off it's center axis.
The first photo shows the chuck in the closed position. In this orientation, it acts like any old screwchuck. The second photo shows it open with the full shift. The third photo shows a front view of the fully shifted chuck.
In case anyone is wondering, I finish the bottom with cole jaws or create a custom jam chuck to fit the off-center dish.
keithz
Re: My off-center chuck
fully open
Re: fully open from the front
Dick Coers
>HMMMMMMMMM, a member of your club huh. Looks like really, really fantastic work!!!
>I agree. He did a great job for me. This chuck really does work. I congratulate and thank him again.
keithz
Al Neighbors
>Keith, thanks for posting these photos. Do you mind if I copy you? I surely liked the bowl you posted a couple of days ago, dyed, limed, and off center. Awesome!
You should make these chucks and sell them.
Steven Antonucci
Is it Steel?
steve antonucci
>Looks like Aluminum in the picture?
Is the screw center just a standard chuck item threaded in from the back? Very cool setup...
Steven
Don Orr
>Looks kind of similar to the eccentric chuck that Ken Grunke produced a few years a go. Glad you like it. The bowl you did is beautiful !
Re: Is it Steel?
keith zimmerman, Normal, IL
>The body is aluminum and the screw was purchased from Craft Supplies.
Thanks. It seems to work well and does what I wanted from it.
keithz
>My chuck, while similar to others out there, is much simpler in design than those. I decided I wanted one something very simple to do only one thing; shift off-center so I could turn an off-center bowl.
So far, it is working quite well for me.
keithz
Mark in B'ham, AL
>Nice simple design. I notice you have it on a Jet and I was wondering about vibration and speed when you go off center.
>There is some vibration when off-center, but it's not too bad. I am able to turn a 6" piece at approximately 7-800rpm without too much vibration. I imagine the vibration would get worse with a larger piece on the lathe. I have been thinking about tapping a place to add a screw and some nuts for balance.
keithz
Great minds think alike :) *LINK*
Ken Grunke from SW WI
>Hi Keith, my chuck adapter started out very similar to yours, 9 years ago. The spindle rotated, and locked with a clamp so the work could be turned from several positions at the same offset. After using that for a while, I used a seperate hub to get the work out away from the plate, and added index marks so my design kind of evolved over time. I've made about 40 of them alltogether, and at least a couple Woodcentralians have one. Don't be afraid to borrow from my design, I don't have a patent on it!
Peace,
Ken Grunke
My original design from 1999
