Have a question? Ask Woody!
jet 1236 broken tailstock-advice needed
Nick
>Help! The c-ring that retains the main screw in the tailstock popped out. It seems to be too small now to hold the screw in place so I can't apply pressure to the workpiece. Jet only supplies a whole new tailstock, no parts. Seems like a pretty flimsy design.
Does anyone have any suggestions for a reasonable repair?
Re: jet 1236 broken tailstock-advice needed
Re: jet 1236 broken tailstock-advice needed *LINK*
Ron in Drums PA
>Is Part Detail #47 what you are looking for?
1236 parts
Ken Grunke from SW WI
>Nick, any well-equipped hardware store will have that c-ring, it's a standard hardware item, Bring the old one to the aisle with all the parts bins and match it up.
You're right, it's a flimsy design--there's a lot of pressure at that point, which should have a thrust bearing instead. I didn't realize it was just a c-clip until I read your post and took mine out to see for myself!
Only $6.22? get the whole screw!
>Although shipping might knock the price up. I would check the hardware store first for that E-clip, which as I said below, is a standard hardware item. Unless the groove it fits into is badly worn.
Yes
Ron in Drums PA
>But it's possible it is a metric size, so take the pin/screw with you (if you can)
Thanks, but...
Nick
>Thanks to all of you for your help. I will hit the hardware stores today. But how do you get the c-ring off and back on the screw? Is there such a thing as c-ring pliers? Or do you just pull it off and force a new one on?
Nick
>No, it's 48-1, the c-ring retainer for the screw. This ring takes all the pressure applied to the workpiece with the tailstock quill. In the headstock there are presumably expensive, beefy thrust bearings but in the tailstock there's only this crumby little clip. The experts say that this is to be expected in a $500 lathe.
Oh, I see
Nick
>Nevermind the post above. I see the ring is included with the screw for $6. Thanks alot.
Re: Thanks, but...
>Nick, just pry it off with a screwdriver. If it turns without coming off, use two screwdrivers. The new one will snap back on with the help of pliers.
After you get it back together, you may want to be a bit easier on the tailstock ram. There's never a situation where you have to really crank down on it. Also, I put a thin coat of white lithium grease on the bearing surface near the clip, and on the screw threads. Now it feels really smooth.
Repair complete- 35 cents
Nick
>Hey thanks again to everyone, particularly Ken. It turned out that the spring clip was not the problem. The clip rides against a flat washer not shown on the parts diagram. That washer wore out so I replaced it with one from the hardware store and plenty of lithium grease. Works like a charm.
Thrust bearings
Nick
>There is one operation that requires me to really crank up the pressure on the quill-when I'm drilling a hole. Then the live center is replaced by a drill chuck and a lot of the thrust needed to advance the bit is taken up by the spring clip and washer. During normal turning, the bearing in the live center probably takes a lot of the load. That's my guess, anyway. If you aren't drilling, then you probably don't need to worry about wearing out that washer or keeping it greased.
Congrats
>I'll have to take a look into mine to see how worn the washer is. Thanks for the heads-up :)
