P&N Tools
P&N Tools
P&N Tools
Steven Smith
>I just purchased a P & N 5/8 bowl gouge. After I turn and drill a handle, do I need to set the gouge in CA glue, epoxy or just a tight fit? Thanks in advance.
Re: P&N Tools
Re: P&N Tools
Doug Thompson near Cleveland
>Steven, use what is available (CA or epoxy) you'll find it doesn't take much to hold them in place.
Re: P&N Tools
Re: P&N Tools
robo hippy
>I have never glued one in yet. I do make the ferrule fit tightly though. No problems with them coming loose.
robo hippy
Re: P&N Tools
Re: P&N Tools
Bill Neddow
>Steven, I have taken apart dozens of commercially-handled tools over the years and have never seen any evidence of glue being used by any company. All you need is a tight fit.
Re: P&N Tools
Re: P&N Tools
Mike Brazeau
>Steven - I have three of these and have found them good value, but if I can ever wear them out am going to be in touch with Doug. I have found however that hey are metric sized and if you drill to the English drill size, they are quite loose fitting, so I have been using 5 minute epoxy to seat.
Mike
Re: P&N Tools
Mike Stafford
Ditto what Mike said...
Mike Stafford
>I found I had to drill the tang holes with a metric drill as well to get a nice tight fit.
Re: P&N Tools
Re: P&N Tools
Brian Hahn in SW Wisconsin
>I use a tight fit, as in hammer-it-on tight. I've never had one come loose. When I changed a few handles, I had to cut and chisel the old handle off.
