Lathe speed for applying/buffing wax?
wilbur
>I usually use a carnabua wax stick for finishing and buff it with a paper towel. I know that for sanding, you want the lathe on a lower speed. Does the same apply for wax sticks when applying it (lathe speed just fast enough to melt the stick on) and buffing (ditto)?
Or should I crank the speed up as high as I can for this?
Re: Lathe speed for applying/buffing wax?
>I don't know if it needs to be as high as it goes but I do use higher speeds for the wax type applications. I apply the Carnauba wax using the 4" Beal buffing wheels and I crank the speed of the wheel up higher than the speed I use on the Tripoli and white diamond.
When I use the Hut abrasives they are applied directly to the wood and then buffed on with a rag stretched between my fingers. I use a speed high enough to melt the wax without applying too much force with the rag. Since the Hut abrasive has a carnauba wax in it I would think that the speed would have to be up to melt and spread the wax.
wilbur
>Thanks, John. I tried going to a higher speed than I had before for putting on wax, and I have better results than I have had in the past.
Of course, it could be that my overall technique has gotten better, too. :@)
