what happened to Bloxogen?
Dick McNeill
>It is no longer sold by the mail order firms. No one knows if they will ever get it in the future? I had just tried it so I don't know if it worked or not. Any info would be appreciated. Dick McNeill
Re: what happened to Bloxogen?
Nick Tuzzolino
>I tried it on a few cans of varnish and paint. The only positive note is, it enhanced Bloxogen's coffers by $10.00. I got skim coats on my liquids.
ditto
Brian Hahn in SW Wisconsin
>I tried it and decided I had better things to spend my money on.
John Leonard
>I have used it for years with great results. I went to order some more from Craft Supplies and was told they had gotton several bad shipments so they had quit carrying it. They are looking for a replacement. John L.
Dave Anderson (PacNW)
>Specialty Wine Shops carry product like bloxogen at much cheaper price.
aveAnderson (PacNW)
Mike Jones, Redding, CA
>I replaced it on my bench with a Bernzomatic (sp?) propane torch...I don't know if it works any better or any worse than Bloxogen, but mostly it works. My Waterlox has not gone bad, and that is all I have to gauge it by. .....what?.....
NO, NO, NO, YOU DON'T LIGHT THE TORCH!!! :0
>I tried it, couldn't tell it made any difference. What a great marketing concept. Sell something that you don't know if you are actually getting anything or not because you can't see it or smell it. Unless you run a control bottle you don't really know if it works or not . You suspect it does because your finish doesn't go bad but you might simply be using it faster. It could be the Placebo affect, or is that effect.
Russ Fairfield
>I think the problem is that, once opened, the lid will never seal airtight again. There is a pumping action from expansion and contraction of the contents with daily temperature changes, and the Bloxygen is soon replaced with air.
bill crommett
>I have had the best results with cleaning off the ridge of the cover and the valley of the can and then taking a big breath. Blow off the bad breath and then blow off the oxygen in the can with the CO2 that has been discharged from your lungs. Then quickly cover the can. This is an old boat finnishers trick that has worked for years. I also use this on cans of nuts to keep them from going rancid.
Dick McNeill
>Thanks for all your responses. I hope CS USA finds an alternative product soon.
Mike Brazeau
>Lee Valley have product called Finish Preserve which is a blend of CO2, Nitrogen and Argon. PN 53Z21.01 It comes up on Canadian dollar web site, not sure for you folks with US pricing.
