Both for crafts fair
Jorge Castaneda~Downeast Maine
>Hello,
I have 3 crafts fairs coming and need a 10" x 10' white booth, (tent, canopy?)
What you all use?
TIA
Jorge
>Hello,
What you all use?
TIA
Jorge
Re: Both for crafts fair
Donna Banfield
>Jorge, assuming it's outdoors, an EZ-Up tent is the most common. Be careful where you purchase it, though. I bought mine online direct, and a friend bought his at Sam's Club. The difference is that my tent walls were made of the same material as the tent, i.e., waterproof. His were not, and we only discovered that...yup...you guessed it, after it rained overnight.
>Many people start with the EZ up. They are inexpensive and easy to set up. They have 2 draw backs. The wind picks them up a lot easier than the good quality booth tents and they tend to leak. The top doesn't stretch flat enough and starts to sag. This collects water and eventually leaks. Some crafters have gotten around that problem putting PVC pipes in certain areas to lift the fabric.
Despite their downfalls they are still a good way to start and see if craft shows are for you. Most only come with 3 sides. If your doing a weekend show you will need a tarp to cover the front overnight. Add some weights to the legs if they won't let you stake it down.
I'm sure others will have some tips those are just the things I discovered before I decided you can't do craft shows and have a full time job. Makes a great tent for family BBQ events.
Jim Jacomb
>check out flourish.com, I saw their products at a spring art fair, they have nice gear and a helpfull web site.
Check this one out *LINK*
Steven Kubien
>I was at an outdoor sale last weekend and the lady behind me had this unit from Sears. 1-1/2" steel tubing and heavy material. It was nice. The size listed is 6'x10' but that is just the area you can cover with walls. The awning-type roof extends out further than that. If I end up doing more outdoor gigs, this is what I will look into.
canopy/gazebo at sears.ca
Thanks Donna and John
>Yes, I see those often and wondered how good they are, as John said, they can be airborne easily but then again they are the cheapest.
I'll look some more I still have a month...
Thanks
Jorge
Thanks Jim!
>That one looks really good, If I can raise the dough
Thanks Steve
>That is nice, but most places I applied specify 10' x 10' white, so nobody's booth stands out.
Re: Thanks Donna and John
>What several of my friends have done is to buy one of the cheapies and use it to get through a couple of shows and then invest that money in buying a quality tent. The good show tents run from $800 on up but they are definitely worth it if you plan to do a lot of shows. They look better, are many times more rigid and waterproof and have some nice accessories like canopies for the front and back and even windows and/or vents in the roof.
EZ Up, and How To Hold It Down.
Joe Pack
>I use an EZ Up from Sam's Club. A previous post mentioned problems with leaks with a Sam's Club EZ Up. I learned that not all Sam's EZ Ups were/are the same. There were 2 different top materials, different deniers. One leaked/sprayed often. The heavier denier, that I was fortunate to buy, does not have the problem.
Also, some come with side walls, some don't. Mine had 4 side walls that zip together and/or are held with velcro straps.
Mine also has a small extension off the front to provide a 2' canopy. It's not all that great, though, because the flimsy wands that hold it in place just can't support the weight and tension.
I borrowed an idea from some other crafters to hold my tent down. I used 4 sections of 4" PVC, each 4' long. I capped one end, then filled the sections with sand. I installed an eyebolt through the top cap, then cemented the cap on permanently. To hold my tent down, I rest a section on the ground at each corner then run a non-stretch sash cord to the top of the leg. I draw the cord tight, but do NOT lift the weight off the ground. The frame is not strong enough to hang that much weight on. The idea is that the wind has to lift the weight off the ground in order to blow the tent away. I do not have to actually support the weights from the frame to do that.
I also learned to strap the weight tubes to the legs to keep them from swinging around.
Re: EZ Up, and How To Hold It Down.
Steve Worcester
>I use a light dome, have for about 6 years. Good tent, definately more expensive than an ez-up, but far more sturdy. The two leaders are flourish and creative energy.
If you can afford it, get it with a front and back zipper installed at the top, that way you can add awnings later. It is easy to setup, if you are doing a show on blacktop, you will need weights, at least 35#-40# per corner. On grass, use heavy tie downs and screw in dog stakes.
I did use an ez-up for years. In the north texas area where we get some heavy storms, I used to get alot of spare parts after a storm from those who didn't lower thier tents and stake down at night.
http://lightdomecanopies.com/sss/lightdome_352_351_8889/index08.html
Donna Banfield
>Jorge, John Lucas is right, as usual, so no surprise, of course ;^)
Another poster suggested that there are EZ-Ups, and then there are EZ-Ups. I don't remember who that person was, but you'll basically get what you paid for in the EZ-Up tents. If you see one that costs less than $100, it's probably going to have the cheaper quality material and is likely to leak, may not have 4 zippered walls, etc. If I recall correctly, mine was just under $300 (which included shipping) several years ago.
Another thing to keep in mind when you're considering your options, the name may say EZ-Up, but don't 'go up that easily'. Whatever tent you decide on, set it up a couple times in advance, so you figure out the tricks. Don't wait until the morning of your first show to discover that it's not as easy as the name implies.
The canopy that Steve Worcester gave you the link for -- you can tell who has been doing the outdoor show circuit for a long time. Many of the well-seasoned arts and crafts show people have made the investment in these better quality tents. The design makes them less likely to become airborne in a storm, or even a gust of wind. And they are waterproof, so no fear of your inventory getting ruined during a summer storm. However, those canopies I've been told really need two people to set up. The EZ-Up tents can be set up and taken down by a single person. This is important if you end up doing a lot of shows without a partner (once you get the hang of set-up).
>Great tips Joe,
much obligated
Jorge
Thank you all
>Steve,
That looks like a fine tent, I'll keep it in mind if I feel I can afford it.
Donna,
thank you again, your input and the others too, makes me feel like it will be easier to make mi mind, thanks for all the tips much appreciated.
Jorge
Paul Zerjay
>My wife and I do many shows per season. We have a Trimline by Flourish. Properly staked, or weighted, they hold up to high winds and are reliable in the rain. I have had easy-ups on the side of our booth and cringe when the wind starts to blow. Its most upsetting when your neighbor's cheap canopy ends up ruining some of your work from blowing into your booth from a small gust of wind.
Most shows we do now require proof of insurance. With our Trimline, we haven't had to use ours yet
Thanks Paul
>The Trimline is the one that Jim above recommended as well, so I am favorable inclined to it, and I like the looks of the round roof.
I also must look into insurance, if you don't mind talking about it, what kind of insurance you carry for the shows and how much of it?
TIA
Jorge
Re: Thanks Paul
Paul Zerjay
>Jorge
When we first started out, other artists told us about policy's called inland marine. Don't ask me why its called that, but when we inquired to our agent about it, he knew exactly what we were talking about. We carry a one million dollar policy from state farm and the premium is less than 200 a year.
Re: Thanks Again!
>That is good to know.
Mil Gracias!
Jorge
robo hippy
>With booths, you do get what you pay for. If all you need is shade, then the cheap Caravan canopies will do. However, you can never depend on the weather. I have the $800 EZ Up, with 4 side walls. I can set it up and take it down by myself. The side walls fit so tight, that 2 of the zippers broke. I took them to an awning place and had heavy duty zippers put on, and 1/2 inch wide strips put on 2 of the sides to loosen it up a bit. It is water proof. If you are on grass, then tent stakes (10 inch driven in at angles, some shows won't allow them due to sprinkler problems) will hold for all but heavy dust devils and up. The weights are another option, but with winds above 20 mph, they don't do well. The Light Domes are awsome, but very expensive. They also take more time to set up. Some Awnings shops have modular units with 3/4 steel pipe and fittings which make a fairly light and strong booth, and it breaks down easily. Sorry, no link for them, but they can be made any size. As far as insurance, if you already have wood shop insurance, then they can include a rider fiarly cheaply. Some shows require insurance, one show I do can give you a policy for their show for $50, some just want a waiver (they are not responsible).
robo hippy
Thanks Robo
>Sorry I was not here yesterday; your input is greatly appreciated.
Jorge
