Vacuum Pump from Refrigerator Parts
Brian McKearney
Brian McKearney
>I have an old refrigerator that will be replaced in two weeks. The electrical parts work fine - just doesn't keep things at the proper temperature any more.
I know that this has probably been posted before, but I was wondering if it is worthwhile to attempt to make a vacuum pump for turning from the parts?
If so, which parts would I need to remove?
Can anyone refer me to instructions for making a vacuum pump from refrigerator parts?
Brian
Re: Vacuum Pump from Refrigerator Parts
Re: Vacuum Pump from Refrigerator Parts *LINK*
>Hi Brian,
Unfortunately your frig compressor is too small for a turning application. See my write up on the AAW forum at the link. All's not lost, however, if you have an appliance repair shop near you. They've most always got trashed units ready for the dumpster and will usually be happy to let you just take'em for free. Just make sure that you also keep the Freon Recovery certificate that they have put on the unit; without that it can cost you up to $100 to have the junk recertified before you can throw it away.
Keep this in mind as well when you're getting rid of your frig. It must have the Freon removed by a qualified tech. and a certificate attached before anyone is allowed to take it as junk/trash/scrap.
mm
Vac-Pump Cheap
Carole Valentine
>Turn it into a drying kiln.
