Jet 1642 Remote Switch Issue
Scott Hurley in N. VA
>A few months ago, I installed a Powermatic remote switch on my Jet 1642. Everything worked fine until a couple of weeks ago, when the remote switch quit working, but the main one still worked fine. I removed the remote and tested it with my continuity tester - nothing. I opened the switch case and tested it directly on the contacts of the switch - nothing. I also couldn't see any sort of fuse or anything like that. However, I did notice that the switch has two sets of contacts - I tested the second set and they had continuity when the switch was on. I moved the wires to the spare set of contacts, and everything's OK now. Bottom line - if your remote switch fails, it may be a double pole switch - just move the wires to the second (spare?) set, and it should work again. When the second set of contacts fail...
Scott
