Drum brake lathes?
Drum brake lathes?
Drum brake lathes?
ThomD
>I do my woodturning on a Harrison short bed and a Conover. I still can't help noticing how cheaply drum brake lathes are being sold off for. Just the lattest casualty of the everything is cheaper from China movement - it no longer pays to turn drums. The result is big wacking sturdy "lathes" selling for 200-500 dollars on craigslist. These lathes are specialized for turning cast drums which probably means real slow speeds, and neither correct spindles or rests. Myself I have never seen a drum brake lathe close up and don't know if they would serve another purpose. Anyone looked into this?
There used to be normalish lathes by the likes of South Bend that were designed to turn drums. Those would probably be pretty desireable in a number of hobbies, but the spcialized lathes are more limited and currently increadibly cheap.
Re: Drum brake lathes?
Mark Williamson
>I really hope someone respondes to this?! LOL
Mark in VA
Peter Teubel
>"Just the latest casualty of the everything is cheaper from China movement - it no longer pays to turn drums."
I think its mostly the auto manufacturers that are to blame. They spec the minimum for weight reduction (better MPG) and to a lesser extent, cost. Discs and drums today cannot be turned because they would become too thin to be safe. That's just the way they are made today.
Mark Williamson
>I would like to know if you could use a brake lathe to turn large scale wood turnings if slightly modified somehow or not? I guess I need to go to an auto shop and take a look at a brake lathe up close.
Mark in VA
