OT Web Page Access
OT Web Page Access
OT Web Page Access
Stuart Johnson
>When setting up a web page, the directory or page title, I have a problem with case. For example a directory titled NewShop will return a "404 not found" if it is entered as newshop rather than using a capital N and S.
I would like the page to open regardless of the case entered. Is there a way to do this or should I just start using all lower case?
Re: OT Web Page Access
sean Troy
>A couple of things. Depending on the server it's hosted on you may need to insert an underscore between words. Another, .htm and .html on the end may be different depending on the hosting company.
Ken Grunke from SW WI
>In my experience, file names in a web address are always case-sensitive. I always use lower-case as that is the most likely to be used.
Domain names, however, generally will work either way.
www.wOOdcENtral.com/russ/russindex.shtml will always get to Russ's Corner, but www.woodcentral.com/russ/RUssindex.shtml won't.
Re: OT Web Page Access ..Thanks
Stuart Johnson
>I finally found a site that explained Unix and Linux are both case sensitive and they are what most server use. I'll just have to remember to use only lower case.
Rick Allen
>There are several ways you can do this:
Put your web site on a Windows server which is case neutral.
Make a copy of newshop.htm as NewShop.htm
You can also make redirect pages so pages with different names can open the web page you desire.
index.htm will open when your web site is addressed.
For example if your web site is www.stuartjohnson.com and your main page is index.htm then
http://www.stuartjohnson.com
is equal to
http://www.stuartjohnson.com/index.htm
good luck
