Drying blocks
Jim King
>I very much enjoyed the drying chunks post below. I have tried everything and some with absolute failure and some with almost success. I air dry planks up to 4 inches thick for a few weeks with strong predrying fans on the stickered planks and then put them in the kiln knowing that I will never get them dry to the center but it helps a lot. I hate the feel and mess of wax and anchor seal so I have started using anchor seal and then shrink wrapping them after drying so as to eliminate the wax mes as much as possible.
Even this has not entirely solved the problem. The small 2 x 6 or 4 x 4 rounds are easy but when you talk about 6 x 12 salad bowl blanks it is another problem, almost impossible. To add to this a lot of inexperienced turners are afraid of even hair line cracks.
For me it is easy, I turn to 1 inch thick and boil the peices for a few hours and then air dry a few weeks and then in the kiln for a few days prior to finishing. Even with this system I could not live without superglue, the turners Saint.
Here is a photo of some peices I turned as gifts using roughing, boiling, air and kiln drying prior to finishing.
PATIENCE IS THE KEY
