skew chisel
richie croce
>Id like to know ,with an ordinary skew chisel about 1 to 1 1/2 inches wide how big of a diameter of of wood could you safely turn?
skew chisel
richie croce
Re: skew chisel
Ralph
>I'm certainly no skew expert... but I suspect as large a spindle as your lathe can handle. Honestly.
In the hands of someone that actually knows what they are doing (ie not me) I have seen someone (Alan Lacer) turn a top that was barely and inch by an inch (with a spindle of about 1/8 inch) and rough a cylinder 6 inches across (using the same skew)
Re: skew chisel
charlie belden
>Are you cutting all side grain? If so, I've roughed up to about 9" diameter - because
a JET mini only has a nominal 10" swing. If the grain is 90s to the center it gets a bit tricker since you're cutting with the grain then acrossed the grain how ever many times your rpm is set to - and most of the time your "in the air" Higher rpms mean less time "in the air" - but if something goes wrong . . .
If you put a curve in the cutting edge you can minimize the likely hood of having the "long
point" dig in. Trouble usually is at the ends of the piece. If your cutting towards the end then you can get some nasty split out when
grain axis is 90's to centerline of the lathe.
I use a half inch and 3/4" curved edge skew a LOT - and probably do some things a skew is
not the best tool for. I think it's a matter of the amount of use / experience you have with the skew. If you try enough ways to do something with it - you'll probably come up with a way that works - for you - sort of.
Try on something smaller and work your way up to larger diameters. Stop after you start scaring the bejeezus out of your self - on a semi-regular basis.
You are correct sir.
steve antonucci
>I think the answer is that it depends on the user. I routinely use a skew on the outside of bowl and hollowforms to make my end grain cuts and refine the surfaces. It requires more attention to the details, but I'd agree that it largely depends on how much wood you can fit over the ways, not the tool...
Steven
Re: You are correct sir.
richie croce
>OK guys I guess Ill have to practice somemore with that skew.
Re: skew chisel
Fog Tanner
>Depends on the size and type of the cut you take. The larger the diameter, the shallower cut or smaller shaving you take on a planing cut. You get into trouble on really large diameters when the cut could exceed half the width of the blade. Then you could easily have the tool roll and the other point dig in and at the least get a spiral run back. At worst have the whole blade dig in and leverage out a piece of wood. Peeling cuts are a different story.
I use a 1" on 6" cylinders when making planing cuts. I don't really care to turn larger cylinders than that with a 1" skew. Its doable, but the margin of error gets very slim and the cuts lighter.A 1 1/4" or 1 1/2" would be better for larger work. I do know someone that made a 3" skew for doing large pieces to get around the problems with a smaller 1 1/4". This is all engrain, as I would never use a skew on face grain where the edge can self feed into the wood too easily.
Re: skew chisel
Bill Grumbine (Kutztown PA)
>Richie, as it has been said, it all depends. The more you practice, the better you get. I turned these last year, most of them with my 1 1/4" Crown skew, which is a little over 5" long in the steel, and not much more in the handle. It was way too short, and I had a horrendous catch on one, inspiring me to get a Lacer skew, since it was substantially longer and a little thicker.
The transition was from 7 1/2" square to 5" round. That doesn't sound too bad until you realize that from corner to corner the distance is about 10 1/2""! That made the pommel cut about 3" wide on each point. Here is what it looks like when it goes wrong.
Good luck with it!
Bill
Re: skew chisel
Don at Central Illinois
>I'm glad to see that a 'master' turner can still produce some of the same things I produce trying to learn the skew. I know, practice, practice, practice.
