Jet 1236 Tailstock Problem
Eric241
>Jet 1236 Tailstock Question
I bought a used Jet 1236 from a friend. I have used it now for 6 months or so with no issues. Just yesterday, however, I was turning a bat. I took it off the lathe to weigh it, then returned it to the lathe for some fine tuning. When I tried to crank up the tailstock it didn't move. I ended up taking the tailstock apart to find the threads inside the quill were basically ground away to almost a smooth surface 3/4" inside the quill. The screw obviously had no threads left to grab and advance the quill. It seems you often hear turners suggest not to lock the set screw on the quill when you turn, and every so often give the tailstock a little crank to tighten up on the workpiece. I'm afraid this is the cause of my now, smooth threads. Has anyone else had this issue?
Re: Jet 1236 Tailstock Problem
Aage Rendalen
Replaced my quill twice
Aage Rendalen
>Before I upgraded to Mustard, I replaced my Jet 1236 quill twice--exactly the same problem as you had, with thread chewed up. I suspect that it had something to do with the lowest pre-set speed being high (450, I seem to remember) and the use of out-of-round blanks that created a lot of vibration.
Bruce Forrest
>Also replaced twice in about 4 years (on a General 260). I now consider it just part of the cost of doing business, and fully expect to replace it again in another couple of years, but at $100 it's not too bad.. I just hope that the motor controller isn't the same. I've replaced it once, and it's a LOT more expensive.
>Most interesting. I rebuilt my first good lathe with Delta 46-700 tailstock quill and I used a Nova 3000 for about 3 years and now my Powermatic. I've never had that problem and I'm hard on the tailstock. They must be making that quill out of softer material.
>Turned on my 1236 for several years, sold it to a friend 5 years ago. Not a single issue. Maybe this is a l-o-d with parts.
Aage Rendalen
5 years of bowls or spindles?
Aage Rendalen
>What kind of turning work did you do?
I wonder if the Jet 1236 is designed for spindle work rather than bowls. I used mine exclusively for bowls and I only had it for a year and a half (and replaced the quill twice).
Re: 5 years of bowls or spindles?
pete in Holland, MI
>Does anybody oil/grease their moving parts on their lathes? I know that draws saw dust, but when assembling my machines, all bolts/screws that will routinely be used were oiled/greased, including the threaded quill on the tail stock.
Metal lathes last for years, but they are designed to be oiled in all locations routinely. My 1922 South Bend is still performing well.
Running metal pieces together in high stress situations without any lubrication leads to gauling and eventually premature failure. We all insure our car engines are oiled, and all know the concequences when the oil runs dry. Woodworking machines often fail prematurely due to lack of simple lubrication.
Re: 5 years
>I did mostly bowls for 2 years with the TS engaged (for safety) until the final hollowing. Comment was made that the sizes I was turning, 8-11-1/2" were asking a lot of the lathe.
Friend I sold it to does a mix of smaller (3" max) spindle work and medium bowls.
Don't know how others do, but I've always tried to use the minimum amount of extension needed by bringing the TS up as close as possible to the work so there's more support and less flexing force put on the quill. If the drive spur gets loose, I don't merely depend on the TS as a handy "ram" at any extension from the casting, but rather stop the lathe, and move the entire TS closer before adding pressure. It's very rare that I have the quill extending more than an inch or so from its stop. This keeps the maximum number of threads engaged in the quill and is far less likely to strip threads. The 1236's ram only has 2-1/4" of travel. If you crank it out 2" from the stop, that leaves only 1/4" of screw threads engaged to absorb all the stress of turning the workpiece and maintaining pressure. Think you'd be asking a bit much of the machine that way, but TJMO, YMMV.
mm
Re:I keep my tailstock quills....
Jamie Donaldson
>....greased with graphite based grease. Only have to do it about once every 2~3 yrs. so it's not much of a constant maintenance program, and there's not much other lubrication accessable on a wood lathe since the bearings are sealed.
