OT: �Fume� mask help needed
Rich Pearson
>My wife uses a consumer level cleaner (KABOOM) to clean the shower. The fumes are very irritating to her nose and lungs. All windows are open and the exhaust fan is running � to no avail. KABOOM�s active ingredients are �organic acids, surrfactants and fragrance. Contains no phosphorous.�
I am looking for an effective (not the cheapest) mask / respirators, etc. which will filter out the fumes.
Any suggestions?
Thanks.
Rich Pearson in Mill Creek, WA
Re: OT: �Fume� mask help needed
Barbara Gill, Remlik VA
>Both North and 3M make a face mask to which you can add chemical filters. The North is the 7700 series. Lots of sites will come up when you Google. Also the North is carried by Granger. I have used the North since 1985 but understand the 3M is also good.
Brian Hahn in SW Wisconsin
>I'd use a standard respirator with a filter cartridge for organic fumes. Most home centers and many hardware stores carry them. They work for all of the organic fumes I've encountered.
>Same as the others mentioned - I use a standard 3M respirator. I swap out dust filters on for some sanding and volatiles filters for spraying chemicals. I also find the 3M full face shield version wonderful for spraying and in situations where I want to keep things out of my eyes.
time to re-think the cleaner
Sam
>why use cleaners that require respiratory protection?
doesn't sound logical
Thank you all!
>I'm going with the organic vapors mask idea and you've pointed me in the right direction. Even though I moonlighted as a janitor early in our marriage, My bathroom cleaning skills don't make the grade with SWMBO!
