ADVERTISE HERE - FREE TRIAL
HannesTool Sharpening Video on YouTube *LINK*
Donna Banfield
>I couple weeks ago, Bill Neddow started a thread about JoHannes Michelsen's new gouges. The gouge has a grind that is done free-hand, without the aid of jigs. Although I doubt that I could have repeated this grind when I was a novice woodturner, it is a grind that I use all the time now. I say this because I teach woodturning at a couple of the local woodworking stores, and when I show beginner woodturners how to sharpen their tools, they fall into two categories: they are either extremely timid, and stand so far away from the grinder (out of fear??) that MY back hurts watching them try to sharpen; or they're SO aggressive, that in the process of grinding, they let the tool slides right off the side of the grinding wheel.
Hannes has just put a video up on YouTube, showing how he gets the grind on his tools. Note, in the video, he is taking a bowl gouge with a fingernail grind, and reshaping it with his signature grind. Once you have the grind established, it takes but a few seconds to get a fresh edge on it, because there's no setting up a jig on your tool shaft, setting a wolverine slide arm, and checking to ensure it's at the right length/depth. You just walk up to the grinder, turn it on, do one side, the other side, blend the tip...done and back to the lathe.
Again, the grind may not be for everybody, but I sure love it.
http://youtube.com/watch?v=wevTPeJoOrs
Re: HannesTool Sharpening Video on YouTube *LINK*
Ian
>thanks for the link donna.
IAN
Al Neighbors
>Donna, thanks for posting this link. I'd like to see him using this grind sometime. I'd like to try it, too. I couldn't see the grind very well in the video.
Is there any chance of you posting a closeup pic of your grind?
Donna Banfield
>I'll try to do that this weekend, Allen. The weather here in New England is supposed to be rainy, so I'll be able to spend some quality time in the shop again.
GaryG in MD
>Allen,
Doug Thompson posted these a while back:
www.woodcentral.com/cgi-bin/turning3.pl?noframes;read=183395
and the following link.
...Gary
Doug Thompson near Cleveland
>Thanks for posting this, I've often wondered how he changed the grind over to his. I only give him a rough nose angle and knock the corners off so he has a lot to grind away.
I use his grind but would never post a picture... it's not pretty but it works.
Al Neighbors
>Thanks, Gary, that's what I was looking for. :)
Al Neighbors
>I'm going to try it with your 1/2" U flute gouge, Doug. If I like it, I'll try some more! :)
>Al, I would suggest the 1/2V for this grind. (it's off the site but I do have one more hidden away)
Re: Ugly
Ron McKinley
>I have several friends that freehand grind their gouges and they're not pretty! Dozens of facets or mini-bevels all over the bevel�but they work! Dunno how. There's nothing prettier than a uniform bevel like the Vari-Grind or similar jig makes......Ron
Re: Ugly *LINK*
Tommy Holmes
>Was digging around in the WoodCentral's Tool Grinds Page and found what looks like to me a similar grind on a bowl gouge submitted by Russ Fairfield. It's the second from the bottom of the page. Russ also says that the multi-facets don't seem to affect the cut.
http://www.woodcentral.com/newforum/grinds.shtml
Re: Ugly
>LoL they can look very rough... the only thing that matters on this grind is the nose angle is 45 degrees and the wings are ground 45 degrees measured FROM THE FLUTE. The bevel is ground away except for maybe an 1/8 inch and everything else never touches the wood so it doesn't matter if you have a hundred facets.
A tool gound with a small bevel is very easy to use but it can't be done on the Wolverine.
Re: Ugly
Tommy Holmes
>Your explanation about the 1/8" bevel and the 45 degree grinds lets me get a really good understanding of how to grind this. Thanks.
Hey! We could have an ugly gouge contest after this thread.
Re: Ugly grinds- I used to be king
>When I was first learning to turn my grinds were so faceted I thought about taking up diamond cutting as a hobby. I eventually learned how to sharpen correctly (at least in my feeble mind). Don't let ugly grinds stop you. The more you turn the more you sharpen. The more you turn and sharpen the better you get at both so just go for it.
Re: For Al Neighbors
Donna Banfield
>Al, sorry, but the meteorologists in New England blew it. The rain ended by 10 am, the sun came out and stayed out all day.
We (my husband Dave and I) have been working on getting a grapple load of logs cut, split and stacked for next winter. We've been at it for 3 weeks now in the evening and on the weekends. Man I'm tired of looking at wood that I can't turn!!
Anyway, someone already pointed you in the direction of what Hannes' grind looks like. Doug Thompson also recommended using a V-shaped gouge, rather than a U-shaped gouge. Below is a photo of an old glaser gouge (U-shaped, that's how old it is), that I reshaped with Hannes' grind. The thing that is missing on the U-shaped flute is the 'fatter cheek', if that makes any sense. If you're using a V-shaped flute, you have some extra steel on the sides, to allow you to 'roll' the tool and keep that round or convex bevel(s). The U-shape flute doesn't have that extra steel on the sides or cheeks, and doesn't give you that 'fullness of the cheek'.
I hope that this makes sense; I'm really 'mathematically impaired', so I may not be explaining this clearly. But I did offer to post photos.... :^)
Re: Ugly
Russ Fairfield
>I have to agree with everything that has been said about the convex profile because I have been using these tools for many years. They are everything everyone says about them. I am surprized that it took everyone so long to discover them. I picked it up from a book written in the early 70's by an Englishman whose name I can't remember (Frank Paine??), and modified it to suit my own preferrences.
I use this tool profile for the inside of tall and thin vessels, and for the finishing cuts on the inside of most bowls, because there is a lot less vibration and grain tear-out. To me, it is the ideal tool profile for re-turning the inside of a rough-turned bowl after it has been dried. Keep it sharp and use it correctly and it will leave a surface on dry wood that looks like it had been cut with a skew chisel.
I still use a more conventional bowl gouge profile for the outside of bowls and vessels because it works better for me. Others may have a different experience.
Re: 45deg bevel with Wolverine
Jerry Hall
>Doug, I think you can create the small bevel in the way you want it with the Wolverine. Kirk DeHeer wrote a neat article in the AAW Journal, I think Fall of 2006, noting the advantages of having the wing angle with respect to the flute equal the nose angle. He also went with 45 degrees. He discovered that when the leg angle of the Wolverine was set to 23 degrees you got pretty much equal included angle between the nose, wing bevel and the flute. I have found that to be true and gone that way for the last year. So it seems to me that you can create a convex surface under the 45 degree bevel by hand grinding or by moving the Wolverine arm in. Then use the jig to maintain and refresh the small 45 degree bevel many times until it gets too big. With the jig you don't take much off and the bevel stays small. If I am right, this would avoid the UGLY grind to some degree and give us hand grind challenged a way to get it done. Does this make sense?
Re: Ugly? Who are we trying to please?
Russ Fairfield
>Who are we trying to please, the wood or us?? The multiple facets on the bevel may look ugly to us, but the wood doesn't know the difference. The only bevel that is important to the wood is a narrow band at the cutting edge. Everything else doesn't matter.
The easiest way to sharpen that narrow bevel below the cutting edge is to use either a slip-stone or the variable speed feature that is built into every tool grinder. With the grinder running, turn it off, let it coast to less than half speed, and grind the edge as it coasts to a stop. Use a light touch, and it will be sharp again without removing much steel.
>Jerry, now that you bring that up it only makes sense... thanks. That's another reason why the Wolverine is the best jig on the market.
Donna's grind doesn't fall into catagory of ugly grinds, matter of fact if it works on that flute I try it on other tools. Stu Batty has his grind that's the same idea.
