Re: what size is the Jamieson swivel cutter?
Lyle Jamieson
>Hi Ed,
The Jamieson system has a 3/4 inch boring bar with a 3/8 shaft to hold the swivel assembly. The swivel is also 3/4 inch in diameter. Consequently you can do hollow forms that have a hole just a bit bigger than 3/4 inch. The Hunter/Jamieson carbide cutter assembly attachment that works better than the hand held Carbide tools has a 3/16 round cutter. In this case smaller is way better. The larger cutters take too much wood at a time. They are harder to use and limit the distance you can hang over the tool rest. I try to open possibilities not limit access.
Now to get to your question if I understand it. The shaft of the Jamieson Carbide cutter assembly is 3/16 square. The carbide insert is on a dedicated angle to give a super clean slicing cut on end grain hollow forms.
The swivel assembly in my opinion is an integral part of my system. It allows infinite positioning of the cutter, again without limiting shapes you can reach. With a dedicated cutter you can reach most places but there will come a day when you can't reach a spot and settle for a thick spot and risk cracking.
So if I understand your question you want to put the carbide cutter in a hand held/dedicated position. And if your hole and set screw will hold a 3/16 square shaft, then go for it. Or drill a 3/8 hole in your boring bar for the entire swivel assembly for both the HSS and Carbide cutter.
Let me digress...The norm is for most turners to purchase a hand held boring bar. It works great for a couple vessels and then most people want to do different shapes so they purchase a "bent" version and its is great for a short time and then they realize how hard it is and try to modify the boring bars to work easier. And they can not hook up a laser so it takes hours to do a hollow form. They see many adaptations of tips and cutters and spend more money retro-fitting the old tools and continue blind hollowing. Sooner or later you will come to the conclusion to jump to my hollowing system the easy way and start really having some fun. The moral of the story...dont waste any more time, energy or money on trying to justify your old purchases. You are worth it!! Enjoy turning more now not larer. Do it the easy way. You will end up spending less money the sooner you go for the right equipment to do the job. Or spend more money to try to upgrade an obsolete boring bar. Just my opinion, but ask anybody that uses my system what they think. As always I am always open to chat with you about the posibilities. Give me a call. e-mail is only one way communication. And my typing finger is already bloody. Regards, lyle
