Drilling Holes in Sandstone?
bowlman
>Anybody have any info on how bore holes in snadstone and what equipment is required ... I assume a hammer drill and masonary bit? ANything else?
Dick Gerard
Re: Drilling Holes in Sandstone?
Texian
>What size holes and how deep? For holes to 1/2" dia. and a couple inches deep, some very cheap masonry bits will do. Beyond that, I dunno.
>I used a standard drill and masonry bits when we put up bolts for rock climbing. It drills quite easily.
jim miles- Charlotte
>Sandstone would not be as hard as concrete. As already noted a masonry bit would work. Also Lowe's carries bits made to drill ceramic tile. I have drilled glass with them. Hammer drill should not be necessary.
Bob Macgregor
>Our whole province is sandstone and, although it varies quite a bit in hardness, it is still pretty soft stuff. I used a carbide router bit to carve lettering into a sandstone block for a headstone for a pet guinea pig and have used masonry blades on a circular saw to cut square edges. I have also bored holes in smaller pieces at the beach just by rubbing (rotating) a sharp corner of one chunk against the face of another. All in all, I think it should be easy to drill a hole in the stuff with real tools, too.
BOB
bowlman
>Thanks everybody for all the replies. I need to drill a 3/4 or 1 inch hole. Sounds like a good drill and a masonary bit will be just the ticket.
