>I have some cut nails, actually spikes, some of which are old wrought iron and some that are new steel. I have need to cut some of them and was wondering if there was a best way to do this. I imagine a hacksaw would work, but I was wondering if there was something a little easier.
>Some cut nails are hardened which would be difficult to cut with a metal-cutting blade in a sawzall or hacksaw. I too would reach for the Dremel. The small cutoff wheels are thin and don't waste much metal.
BTW, about 40 years ago I came up with a great application for these little cutoff wheels. When motorcycles were commonly assembled with philips screws/bolts, removing those with stripped heads was always a problem. I found that I could usually use a Dremel to cut a slot in the head that I could grab with a big flat-head screwdriver bit in an impact driver.
>John When I raced my kawasaki I had constant problems with the philips head screws. I did just as you did using either the abrasive wheel or a a slot cutting wheel and used the impact driver to remove them. I finally learned that Kawasaki sold an allen head screw replacement kit so you could replace every one of those stupid philips screws. What a life saver.
