Where do you do your pyrography?
Doug Bartos
>Thanks to all of you who have made suggestions in the past on what woodburner to get, I recently purchased a Burnmaster Hawk woodburner and three Optima pens. Now that I have the burner, I was wondering where you do your burning. Do you do burn inside? If you are burning inside, do you use a filter, if so what kind? I did some practice shapes and signatures out on the porch, but the light is not as good and it gets cold out there.
Thanks in advance,
Doug
Re: Where do you do your pyrography?
>I sit in my dining room. I don't do a lot of the serious burning that creates a lot smoke so just sitting there is fine. When I do need to turn the temp up and "burn" I have small muffin fan that I place to the side to blow the smoke away. You have to aim it kind of high and not directly at the pen or it cools off the pen and makes controlled burns a little more difficult.
Bob Macgregor
>I was wondering something similar. Does the burning (inside) ever produce enough smoke to set off the smoke detectors?
no but my cooking does. :)
Darryl
>Try locating the fan so it pulls the air over your work. Not only iwll it not cool the tip the air flow will be a bit more steady. I do my burning in the garage where I can open the doors if necessary. For signatures I do it where ever the pens happen to be.
Steven Antonucci
In my shop
steve antonucci
>I have a window in the back, and garage door that I open if I'm doing a lot of burning, but I am not using a pen.
No, sir. I do MANLY burning.
A lot of the stuff I am messing with are branded pieces. I heat a steel brand to glowing and then impress the image into the wood. Usually the first couple of impressions spontaneously ignite the work, but that just adds to the effect.
Smoke. You betcha...
If I'm doing a torch texture over the whole piece, I go outside.
Steven
Molly Winton
>If it's light burning such as outlining or a stipple burn for negative space, I burn in my family room. The amount of smoke is not too bad, probably less than cigarette smoke. However when I'm branding or heavy burning, I have a burn station in my shop/garage located near the bay door. I burn with the door open. In the early spring and late fall I bundle up like Nanook of the North, and if I really need to brand in the winter I keep the bay door closed, use a respirator, and then when done, open the bay to air it out.
Doug Bartos
>Thanks everyone for your suggestions. It sounds like most of you burn in your shops unless you're doing the really heavy burning. I'll give it a shot. Do any of you use a small air purifier/filter?
Doug
Plus caution...
Molly Winton
>I do when I'm in the house.
One note of caution about burning in your shop. Make sure you are in an area where no combustables are. My area is completely seperate from where I turn, with a barrier between the areas. Sparks can fly easily, and it only takes a little one to smolder into a disaster, especially if you're using a fan to help pull smoke away from you. It will also take sparks and send them flying.
