Re: Ci1 easy rougher carbide tool
Craig Jackson
>Hey Guys,
A customer made me aware that there was some discussion of my
Ci1 Easy Rougher going on here. I hope it is O.K. for me to post this info. I thought I would answer questions, and clear up some misconceptions, so you all could get an understanding of the tool and its' concept. I have lots of info at www.easywoodtools.com
All I ask is that you guys investigate the merits of this tool before you pass judgment. If after looking it over, and reading the MANY reviews at Woodturners Resource, you still have doubt, I will send you a tool at no cost for your evaluation. If you like it, I will then expect you to pay. If you do not like it, send it back and I will pay ALL shipping
First of all, I am a master machinist and I assure you metal working inserts are WAY too dull to perform on wood. The inserts used in the Ci1 where designed from the ground up for strictly wood cutting.
As for how does this tool compare to other carbide insert tools with round cutters? It is like comparing an apple and an orange. My tool was designed for removing MASSIVE amounts of material. It does this with little to no fatigue as all the cutting forces are directed straight to the tool rest, period. I have customers with arthritis who can now turn for days instead of just hours.
Another advantage is safety. The neutral top of the cutter all but eliminates catches when you maintain a level tool handle. The square tool bar provides support directly under the cutting edge which completely stops all twisting of the tool.
Craig Jackson
270-771-0955
270-903-4269
