Escoulen Chuck
Escoulen Chuck
Escoulen Chuck
Woodie49
>Does anyone know where I can get a Escoulen Chuck? (off center woodturning)
Thanks
Re: Escoulen Chuck
Re: Escoulen Chuck *LINK*
>His web site lists a number of distributors.
Escoulen distribors
Re: Escoulen Chuck
Re: Escoulen Chuck
elliott
>check crafts supply
Re: Escoulen Chuck
Re: Escoulen Chuck
Ralph
>CS-USA no longer carries his chucks
Re: Escoulen Chuck
Woodworker's Emporium
Bob Elliott
>Christian Brisepierre of Woodworker's Emporium is in Las Vegas. If he doesn't have it he will get it. They will probably have a booth in Richmond too.
800-779-7458
Re: Escoulen Chuck
Re: Escoulen Chuck
Fog Tanner
>There are three, make sure which one you order. I have the first two and they both have different applications. I think that the Cutting Egde still has one or two of the first one (which is where I got mine), Steve never carried the second one. The Woodwokers Emporium is another source. Christian is friends with Escoulen, so he can probably get any of the chucks. He is where I found out about the third chuck. He also carries a DVD made by Escoulen on how to use the first chuck. It is in PAL format and will only play on you PC or a DVD player that will play PAL format. A number of the newer players play NTSC (US format) and PAL (European). Its a good DVD good for some new ideas on what you can do with the chuck.
Craft Supply had a closeout on all the Escoulen chucks they had,so you are pretty much limiited to a couple of US suppilers.
