OSB for shop walls
OSB for shop walls
OSB for shop walls
Stuart Johnson
>I'm in the process of having a new shop built and it is time to start thinking about how I'll finish the inside.
It is a metal building so finishing the walls is really cosmetic and a way to cover insulation. I'll probably frame them with 2x4's on 19+ centers and want them to be sturdy enough to use French cleats for cabinets and tool racks without worrying about finding a stud. My lumber storage will be supported with 4x4's and only attached to the wall to keep it in place.
I will run my electrical wiring in front rather behind the wall covering so I have the option of moving it around as or if I want.
With that amount of information what are the thoughts about oriented stand board? Would 7/16 be thick enough or do I need to move up to 5/8 or 3/4 whatever the next thickness that is now being sold.
Re: OSB for shop walls
>I used 1/2" plywood for my shop walls (the ones that weren't cinderblock, that is). I didn't want to use OSB because of the irregular surface and I figured the plywood would take paint better. I've put some screws in the plywood to hold clamps, guides, squares, etc.
You could probably mount cleats on OSB or plywood reasonably well, but I'd feel more comfortable screwing the cleats into the studs.
My $0.02.
Carole Valentine
>Stuart ever since I put OSB in my old shop and every bug that set foot in there immediately died, I have been nervous about that stuff. My shop toad even died even though he could go in and out.
Stuart Johnson
>Carole, With all the critters we have walking, flying and crawling around I'm not so sure that isn't a plus.
terry quiram
>That is just what I did. 7/16 osb for walls and ceiling. All my electrical is in conduit running on the outside of the walls. I have never regreted it. Stain hider paint over the markings then flat white over everything.
Terry
>Stuart My shop had OSB when I move in. I have a love hate relationship. Mine is thin so screws don't hold all that well. I like it over drywall because you can put screws or nails in it to hold things. I would rather use plywood or something slightly thicker but OSB is half or more less than plywood in price.
Fog Tanner
>I had a similar situation, except mine is a "pole" structure. The "poles" are rectangular and not round. I ran 2x4 "firring" on 24" oc all the way around, starting at 1" off the floor up 8'. I have 9' eves and a 13' ceileing so I just did the wall. I wasn't interested in cabinets as I like moveable shelving units more. The "firring" strips span the "poles" with vertical 2x4's 16" or 24"OC (CRS).
I used 7/16" OSB fastened with screws on 9" centers, which I painted semigloss white. Would not use Behr again though, takes 3 times as much paint. All the electrical is in conduit, except for the ceiling fixtures. For that I used 12ga wire in open air.
Good luck on your project, I just hope I don't have to look at that much OSB again for a while. And so does my back and my daughter (number 1 helper). I think I got my moneys worth out of my screw gun on that one job, I just wish that Home Despot had carried deck screws like they do now - but 20-25 pounds of the other kind will have to be enough.
Texian
>Agree that the 7/16" will not hold screws very well. Maybe use the next thickness. And definitely paint flat white to reflect light. My shop has drywall interior, and no problem locating the studs for shelf supports, but sounds like you need to be able to attach to wall almost anywhere. The rough surface will be a real dust catcher. I left my drywall walls smooth, not textured, to reduce dust collection. My wiring is inside the walls, but have 110 outlets about every 5 feet around the walls, 18 in ceiling for three lighting circuits, plus multiple 220 outlets around the walls and 6 in the ceiling, and dedicated 220 circuits for A/C/Heater and welder. And/but - - did my own wiring, as no way I could afford to pay an electrician to do all that.
Carole Valentine
>I used drywall in my new shop and am glad I did. A french cleat system allows me to put pegboard or cabinets anywhere I want and move them around if need be. I put so many windows in though that I miss the wall space, but do I love the windows.
Ray Johnson
>I am in the process of putting OSB on my shop walls. I have 1 side and almost both ends done.
I did a lot of thinking whether to use OSB or wallboard. Wallboard is easier to paint but you need special hardware to put anything in the walls. Then I got to thinking about the weight of each sheet. Since I am doing ths by myself, I opted to go with 7/16" OSB installed with screws. The last wall is 15' tall so it is going to be interesting when I do that one.
I have a pole barn style building. I installed 2x6 wall framing on 16" centers. I added insulation and wired in 13 - 110v circuits and 3 - 220v circuits. This includes the 2 - 110v circuits and another 220 v circuit that were in the old panel. I put in a new 100 amp panel with 20 breaker slots and have one slot left. Way more than a one man shop needs, but I don't have to worry too much about what other tools are on a given circuit. Also according to code, I had to have a GFCI on each circuit.
I have read a lot of discussion on OSB vrs wallboard. The main argument seems to be the brightness. I had insulation in for a while before I did the walls. It has a brown backing so I figured OSB couldn't be too much different and it was not too dark in the shop. I may put primer and paint it white in the future but so far I like the striped wood look.
Pete in Holland, MI
>Have had 2 shops with 7/16 & 1/2" OSB. Loved them. No......you can't screw shelf brackets to it alone and hold up engine blocks. I do make wood blocks with wood pegs & little shelves to hold up all of my tools & accessories and it works well. Those items requiring heavier payloads, I'll look for studs to tie into.
Drywall may be smooth & cheaper, but is easily dented by bumping it with boards & hanging up tools.
As mentioned earlier, prime with a good stain covering primer (to cover up the printing), then give a couple coats of semi-gloss latex white or antique white before you start to move in.
If you shop will evolve into anything like mine, there isn't much of the wall exposed due to the stuff hanging on them.
How sensitive are you to formaldehyde?
Curly Smith
>OSB was originally designed to be used in well-ventilated areas and wasn't intended for use inside an inhabited building. The high formaldehyde concentrations in the FEMA/Katrina trailers likely came from OSB used in the construction. While you can certainly use the OSB, I'd go with the plywood because the shop toad that I saved might be me.
Re: How sensitive are you to formaldehyde?
Carole Valentine
>I can't help but wonder if that stuff had anything to do with my pup developing a malignant melanoma in her mouth a year later.
charlie belden
>I'd suggest sticking with 16" on center studs - easier to remember and if you're going to skin the walls, works out well with full 4' x 8' sheets - of dry wall, ply and OSB.
Though OSB isn't as smooth as ply, it's just as strong - and a bit less expsensive (avoided the word "cheap" because NOTHING is "cheap" any more - THANK YOU DUBYA! - and don't want to imply that it's flimsy or weaker than REAL ply).
If you use what is "nominaly" 3/4" (it's probably actually 23/32" - or less), and SCREW it to the studs, you should be able to put just about anything you want up anywhere you want using wood screws - no need for molly bolts or butterfly bolts. If it's something heavy french cleats let you use more screws, espcially between studs. Lee Valley has several metal french cleat type things that'll support a fair amount of weight - and still keep the back of the cabinet or whatever very close to the wall (as opposed to making your own out of wood).
Lumber storage racks CAN be very useful and conventient - IF the wood is accessible from the ends AND the front. But if there are front "legs" supporting the "shelves", removing long boards can be - let's just say "inconvenient". Shelves which are only attached only at the back are very convenient. BUT - you better secure that back support REALLY well - to studs - with "real", not sheet rock screws.
Surface mounting your electrical gives you the option to fairly easily change things WHEN the time comes - and it will. No matter how well you THINK you've planned your ultimate shop layout - you WILL want to make changes over time. With fixed in the wall outlets, junction boxes and switches, making changes to the electrical can be a Royal PITA. And go with 3/4" electrical conduit - you may need to add some wiring in the future. May cost a little more up front - but like insurance - if you need it ...
Keep in mind your dust collection "ducting" when working out your surface mounted electrical layout. Unlike conduit which can be bent around obstacles, ducting doesn't lend itself to that. It CAN be done - but the fittings required can be prohibitively expensive.
Oh - if you've got a concrete floor - paint it with epoxy paint. - with a little "special non slip sand" mixed in. Bare concrete floors generate concrete dust - and it's abbrassive as hell. And go with a light gray rather than a dark gray or "brick red" - reflects light better and parts are easier to see when they fall on a lighter floor.
Dear Abby Mode - OFF
Have fun!
charlie belden
Re: OSB for shop walls ,,Thanks
Stuart Johnson
>for all the input. One day I'll be able to post pictures.
jim miles- Charlotte
>Just noticed in Lowes last week the price of a sheet of OSB ( 7/16 I think ) is down to about $4.50 - It has been up to almost $15. in past year or 3. Much cheaper than plywood. Now is time to buy if you go that way.
