ADVERTISE HERE - FREE TRIAL
any experience with Abranet sanding mesh?
GaryG in MD
>Does anybody have hands-on experience with this stuff?
I use Abralon pads, but I've never tried the mesh.
I saw it listed in my latest PSI catalog.
They sell a range from 120 to 400 grit.
It's not cheap, so it better last!
My real interest is the character of the resulting "sanded" surface.
What are the scratches like? etc. ...
...Gary
Re: any experience with Abranet sanding mesh?
Jerry in Indy
>I just received a starter kit of 2 inch disks, 80 grit to 320 and only have used it on a Sycamore bowl. They are very agressive especially at the lower grits and when you are on a curved surface they can dig in a bit and leave sizable scratches. The higher grits do a nice job. Looks like they will last a long time which would help justify the high cost. I think they will have special uses and are not something that you would use all the time.
Jerry
GaryG in MD
>Thanks Jerry. Yeah, they sound a little bit like mini and micro rasps! Thanks for your inputs. ...Gary
Dick Coers
>I really like the finer grits. If you are turning green, and the wood is slightly damp, the sawdust will not stick to the mesh.
Thanks Dick
GaryG in MD
>That's good to know. I guess I'll have to give it a try. ...Gary
John Scheideman
>I tried them and wasn't all that impressed....but maybe it was just me. They do cut well and they don't clog up easily but my problem was that they tended to wrinkle on the sanding pad. Maybe I used too much pressure?
John
Re: any experience with Abranet sanding mesh? *LINK*
>Gary That's been my experience also. It doesn't clog up as bad and sometimes not at all when sanding green wood or oily woods. I save it for those occasions and use Norton 3x 90 percent of the time. Bruce Hoover from the sanding glove now carries the Abranet in fine grits as well as some of the courser grits. For really course grits I use drywall sanding screens. They are much cheaper but only go up to what they call Fine which is about 120 or 150 when compared to Abranet.
http://www.thesandingglove.com/
>I should mention I've only used the hand sanding sheets, not the discs. I would like to try them sometime I just haven't invested in them yet.
keith zimmerman, Normal IL
>I like using Abranet on broad surfaces such as the outside of a bowl. I am not at all happy with it for sanding details as I have found it does not like being folded.
keithz
John, thanks for your info... good to know
GaryG in MD
Thanks all ...
GaryG in MD
>Your comments have painted an interesting picture of its utility -- and lack of such in some areas. I guess like anything else, it's a tool to be used when and where appropriate. Thanks, Gary
Dick Hines
Dick Hines
>I use it on pieces I put stone inlay in. It cuts better than sandpaper. What I don't like is the price. I will stick with plain old sand paper on anything else.
