Gouge Removal
Gouge Removal
Gouge Removal
Jim Tusant
>Does anyone know how or if you can remove a gouge from the handle without damaging the handle or gouge.
Re: Gouge Removal
Re: Gouge Removal
billhale@woodspinner.net
>Simply put the gouge end in a vise and use a wood block against the handle and tap it off.
Bill
Re: Gouge Removal
Re: Gouge Removal
Greg Haugen
>Without damaging either? I think that's a magical trick. If you really don't want to damage the handle, why do you want to take the gouge out of it? Usually in gouge removal something will be damaged or marked? Assuming the gouge is only friction driven, no adhesive applied, you could wrap the handle in a towel and clamp it into a vise. Using a pipe wrench on the gouge, try to twist it loose. I doubt playing with heating it or cooling it will be enough to loosen the tool on it's own. If there was an adhesive applied, heat may get it to deactivate. Other wise when it's time to rehandle a tool handle gets bandsawn down the center of it about 3/4 of the way, staying away from the tool tang, and a dremel cutter is used to cut the ferrule off. After that it's basically a "wish bone" breaking action to free the tool. Most of my tools are seated with a 5 minute epoxy into the handle. If the tool in question is a Sorby, Henry Taylor, etc. with the original handle they don't use adhesives. I've knocked those off by holding onto the tool and hitting the handle with a hammer at a downward angle. This will usually knock the handle off.
Hope it helps,
Greg H.
Re: Gouge Removal
Re: Gouge Removal
>I agree with Bill. I've never had any trouble driving a handle off by putting the gouge in a vise with wooden jaws and then I use a block of wood and my dead blow hammer. They come right off.
Re: Gouge Removal
Easy...
Randy G
>I just used my gouge for a year or two, then one day I noticed it had become loose enough for me to pull it right out. :-)
I'd agree with the others.. Putting it in a vise and using a wood block to tap it out. Good luck
Re: Gouge Removal
Peter Charles Fagg (UK)
Re: Gouge Removal
>I disagree with some of the statements!
I have tried unsuccessfully to remove a Robert Sorby 1/2" gouge from its handle. I only succeeded in smashing it across my shop.
I have tried heating it gently right up by the handle and ferrule but still it will not budge!
I have held it in both in an engineers vice and the type with wooden faces but it will not move!
I would be interested to hear more from others!
Regards, Peter.
Re: Gouge Removal
Re: I have rehandled my Sorby bowl.....
Jamie Donaldson
>....gouges several times by grabbing the tool shaft in a vise and knocking the handle free. Take a stick of hard wood like oak or maple and place one end against the handle ferel(sp?)and give the other end a few good whacks, and it slides right off.
Re: Gouge Removal
Gordon Seto
>It may have to do with humidity.
I did some pens using the guts of Bic pen and took them to Taiwan last winter. I was afraid that the pressure in airplane would cause the ink to leak. I packed the ink separately. I couldn't insert them back into the pen body because the wood has expanded.
With the metal ferrule, the wood has only one direction to go.
Gordon
