A55 Smoothing Plane
Shellac Sanding Sealer Question
dan oliphant
>I have a question for those of you that understand how wood reacts with alcohol.
First some background. I do my turning in the following sequence;
Rough turn green wood, DNA soak for 4 to 5 days (because I'm not in a hurry), double bag (brown paper bags) ends sealed, allow to set on shelf for 40/45 days. The Rh in my area averages about 15%, remove from bags and allow to set in the open until I'm ready to finish turn. I then allow the sanded piece to set for a few days prior to applying a finish. In my mind the piece should be pretty well stabilized when it comes to wood movement.
On two separate pieces, one Juniper, the other an unknown species of conifer, when I applied a 2# cut shellac sealer to the inside surface (both hollow forms) as the first step, the piece will start to crack like a hard boiled egg within seconds.
Is this cracking caused because the cells in the wood re-expand too fast when exposed to alcohol? Is shellac the wrong sealer for HF pieces?
Re: Shellac Sanding Sealer Question
Mike Jones, Redding, CA
>I don't know the reason...but I had the same experience with a large redwood bowl that split first down one side then the other as I stood there watching in amazement. I had slopped a generous coating of Zinzer's Bull's Eye shellac sanding sealer to the interior surface, and was cleaning up when it popped with an almost musical 'crack!'. As I stared at the 1/2" gap (at the rim), the other side popped also.
This was straight-grained, old-growth, heart redwood that had been in an attic for 20 years or more.
Go figure!
>I had the same thing happen one time when trying to bleach some Cedar. I think the bleach penetrated the wood too quickly and caused it to expand at that point and crack. Ihaven't tried it yet but I think if I first sprayed it with water this might swell the fibers so the bleach wouldn't swell them as quickly.
Maybe the alcohol is doing the same. You didn't say how thick the vessels are. Perhaps a thicker cut will work. I will be interested in what other think. It could be spraying them with alcohol would work but I'm purely guessing.
GaryG in MD
>Hmmm... I don't know the answer, but I'll note that all 4 pieces of wood mentioned so far have been conifers -- no hardwoods. Is that a coincidence or a trend? ...Gary
Just an observation but
Jerry Hall
>in both cases the inside was sealed and the outside wasn't. Could the differential in drying between the two surfaces, one sealed, one not in a hot dry environment be the distinguishing factor? Kind of like overheating while sanding the outside and getting checks? Confers would also seem to be more subject to rapid drying, particularly after exposing more damp interior wood. Just mind wandering here...
What I did next time...
>This big bowl was made from the same timber as the one that split. I inset the brass into the rim to contain it should it want to split too. Pyrography by my Marianne.
Re: Just an observation but
Al Neighbors
>You're right, I believe. Sealing the outside of a bowl and leaving the inside is the suggested way to help it dry without cracking. Seems that sealing the outside allows the inside to dry and shrink while pulling on the outside. The opposite of this may be one problem.
Re: What I did next time...
GaryG in MD
>That's a VERY pretty bowl, Mike. Nice work. ...Gary
dan oliphant
>Thanks for the input. I have a few more pieces that will be ready soon, I will use lacquer sanding sealer instead of shellac then add any dyes that I may use to the lacquer top coats.
Al Neighbors
>I'd put it on the outside, and let it set up for a few minutes, before I put it on the inside of hf or vases.
dan oliphant
>I agree with you, the outside will be coated with sanding sealer first on all future pieces.
Al Neighbors
>I commend you both. Beautiful! Strange pyro, but beautiful! :)
