Making aluminum caliper?
LARRY BISBEE
>I would like to make my own calipers out of aluminum, but can anyone tell me the best thickness to use, the best way to cut the caliper shapes from a sheet of aluminum, and would aluminum alloy 5052-H32 be okay to use for this project? In a demonstration at the 2008 Southern States Symposium, Avelino Samuel used three different sizes of these calipers to measure the thickness of his vessels and I have also seen them used before in other demonstrations. Suggestions and comments would be greatly appreciated.
Re: Making aluminum caliper?
>Larry,
You can easily cut aluminum to the shape you need with a woodworking bandsaw. Since there will basically be no force on the calipers, almost type of aluminum and any thickness enough to keep it from flopping should work fine.
Don't use your 3TPI blade though!
Bill Howatt
Larry, I made mine...
Allen Neighbors
>from an old STOP sign the highway department threw out in the metal pile at our landfill. It is stiff, and works perfectly. I used a metal blade in my jigsaw to cut it out. I drew two 3/4" wide Ss, side by side on the backside of the sign. Then I cut them out, and flipped one over and put a small bolt and wingnut in the center. It's now in the shape of a figure 8, split at the top and bottom. When it's apart 1/8" at the top, it's apart 1/8" at the bottom too.
Two or three different sizes of these will work, also, and they're not so hard to draw and cut out.
Re: Larry, I made mine...
>I built a different one but I used plexiglass. I used a scroll saw.
robert davis
>imade twosizes similar to photo from scrap aluminum appx 1/16 thick using metalcutting blade in scrool saw. very slow speed . lubricate with wax
