>okay guys, what do I use to seal the end grain of freshly cut logs to help prevent checking. I'm not looking for anything fancy nor expensive, just something that works and is reasonbly inexpensive.
>You can find Anchorseal by the gallon at Woodcraft. It's cheaper if you buy a larger quantity direct from UC Coatings. I once bought a 55 gal drum but they also sell in 5 gal buckets. There are other similar sealers that might be less expensive or more readily available in your area.
Anything that stops or slows the moisture loss through the end will work. Anchorseal is just wax in an emulsion. Some people melt paraffin and brush or dip the ends. Paint will supposedly work, although perhaps not as well as sealer. I've read of people using roofing tar but that sounds messy.
>Wax works the best. AnchorSeal is a popular wax emulsion. A furniture paste wax works (i.e. Johnson paste wax), but it might have trouble sticking to wet wood. You can make your own with paraffin and mineral spirits. I've also used melted paraffin, but it is harder to apply.
Second best is shellac. Apply several coats.
Latex paint and primer also work. Several coats work better.
I've tried a variety of other methods, but the results haven't been nearly as good.
I now use AnchorSeal for end grain and shellac for side grain.
Yep, anchor seal is the best, however, no sealing of end grain will keep a log much longer than about a year, depending on conditions. I'm going through my wood stash (logs sitting in the dry for about 2 to 4 years and most of them are going to be firewood. Far better to process the green wood into blanks asap. Taking the bark off of large chunks and completely sealing the outside with anchor seal will maximize longevity.
>I have to store my logs in the driveway out in the sun. As near as I can tell no endgrain sealer I've tried saves them for very long. Anchorseal has been as good as anything and a heck of lot less mess than trying to wax the ends. You do need to seal the ends but I think storing the wood out of direct sun is probably one of the best things to do.
>I stumbled across a poor old polar cut into chunks. I took home a few pieces of crotchwood and rough cut them into blanks on the weekend. There's some nice grain in there.
Since I didn't have any wax or log end sealer I just put the pieces into garbage bags and they're sitting on my back step.
How long can I keep them like that?
I'd like to encourage some spalting. Anything I can do? Perhaps my snotty nosed kid can donate some bacteria and/or fungus to the blanks.
I bought some wax sealer today. I'll probably paint the blanks tonight.
I won't have time to rough out any bowls or platters until probably next week, and even then it will take me a week to do the roughing on all of the pieces.
>Remember: You are not trying to " seal" the end grain. You want it to dry out, you are trying to slow the process to equalize the moisture loss from end and the sides. Whatever you use is eventually going to wind up on the shop floor as waste. My preference is miss tinted latex paint from Lowe's - $5.00 or less a gallon it does take 2 - 3 coats
>>...equalize the moisture loss from end and the sides.
Seems like that is IF you want it to dry which makes more sense with boards than large turning blanks or logs (the subject here). It may take many years to dry a log or log section.
If you want to preserve a turning blank, sealing it completely will keep it "green" and prevent end grain checks and cracks as long as possible, especially if kept cool. Logs recovered from even many years of submersion in water are often in good shape.
