A55 Smoothing Plane
Lathe Height?
Lathe Height?
Lathe Height?
Tom
>I have been getting back into turning a bit and have a question. It seems tto me that I am leaning over too far to work on my lathe. What is a recommended height for the lathe(bed or spindled center line) to be at?
Thanks
Re: Lathe Height?
Re: Lathe Height?
>Tom A good starting point is with the drive centers at your elbow height. I have mine about an inch higher. I was having back pains until I raised it. If you get it too high it makes you want to raise your shoulders which get tired easily and you can get neck pain. Too low and you get lower back pain.
Re: Lathe Height?
Re: Lathe Height?
Greg Haugen
>When your standing next to the lathe, the height of the spindle should be approximately level with your elbow. This a "general" rule. For spindle or Box turning, I like this height. When I was turning bowls almost exclusively I liked a lower height since I turn the larger objects a little more from the hip.
Hope this helps,
Greg H.
Re: Lathe Height?
Steven Antonucci
Depends on what you turn
steve antonucci
>Spindle= higher
Bowl= medium
Hollowform= lower
Each one is a bit more suited for the work than it's predecessor. It's all about being able to make the moves you need to make for the cuts.
Steven
Re: Lathe Height?
Re: Lathe Height?
>I agree with John. The "traditional" advice is elbow height but I find that too low for the type of turning I do. I personally think the optimum height depends somewhat on the turning you do.
I wonder if the elbow height recommendation comes from big block turners. I mostly do small things with a lot of detail and I think the higher spindle is easier for this. The height I use is probably too high for comfortably hacking out heavy hollow forms. For turning big bowls, I don't think the height matters as much.
While the ideal lathe might have an easy height adjustment, I suggest putting the lathe up on a series of blocks, perhaps made from plywood, until you find the height that suits you best. (Be careful that all four legs stay perfectly level or the warping can cause misalignment between the spindle and the tailstock.)
Re: Lathe Height?
Re: Depends on what you turn
>The same thoughts at the same time. That's scary.
Re: Lathe Height?
Re: Lathe Height?
Brian Hahn in SW Wisconsin
>I agree with the previous advice. It really depends on you and what you are turning.
For me, the elbow height is about right for spindle work. For a while my lathe was an inch or so below that and I was getting tired from bending over too much. I stuck pieces of 2x4 under the legs. That made the lathe a little too high and my neck and shoulders were getting tired.
I like the lathe an inch or two below elbow height for bowls.
Fortunately, my new lathe has infinitely adjustable height and I can easily change the height to suit my current turning activities.
Re: Lathe Height?
Steven Antonucci
great minds think alike ;-)
steve antonucci
Re: Lathe Height?
Re: Lathe Height?
Wally Dickerman in Arizona
>As others have said, it depends on what you regularly turn. Most of my turning is hollow forms. I use a Stewart tool and if the spindle height is about 3 inches above my elbow so I can stand comfortably while facing the piece. Not tiring at all. I find that for me it's also a comfortable height for spindle turning.
Someone once posted that for him nipple height was about right. I live in a retirement community of senior citizens. Someone said that the average bra size here was 34 long, so maybe nipple height wouldn't work here?
Wally
Re: Lathe Height?
Steven Antonucci
34 Long? That's funny!
steve antonucci
Re: Lathe Height?
Nasty image Wally.
Steven Kubien
>Dang, and I just ate lunch!
Re: Lathe Height?
Ooooh, that's harsh,,,but funny...
Eddie Pacheco; San Jose, Ca.
Re: Lathe Height?
Hey, watch it! For some of us that's not funny! :)
Molly Winton
Re: Lathe Height?
Re: Hey, watch it! For some of us that's not funny
>Well Molly, when most guys here try to belly up to the bar they're still standing too far away.
Wally
Re: Lathe Height?
I, too, was leaning over too far...
Allen Neighbors
>and my back and shoulders hurt all the time. I raised my Spindle height to 49" and the pain ceased. I haven't looked back.
I used two stacked 2x6s as risers under each set of legs, screwed to the floor, with lathe screwed down to the risers.
Re: Lathe Height?
Dick Hines
Re: I, too, was leaning over too far...
Dick Hines
>I wouldn't get into other thing about 34 long. Back to the lathe height. I have a set of 4x4's under the legs of my PM 3520, and the leveling feet are all the way up. That gets the spindle up to 54 inches. Good for me bad for anyone under 6". Carole V. came over a while back and she had to stand on a milk crate so she could reach the piece she was working on.
Re: Lathe Height?
Re: Lathe Height?
jim miles- Charlotte
>Well I will be the different one. I turn mostly big bowls & hollow forms. My lathe is 36" about the floor at center point. That is about waist high. I built the lathe low, knowing I would be able to raise it later, but not lower. I just got use to it at that height. I find several advantages. I can steady a tool against my hip and use my leg muscles to push into a cut when I am roughing, also I think I can get better control on a finish cut. I can sit down to sand. Just got use to it this way & it works for me.
Re: Lathe Height?
Re: Lathe Height?
Rich Egan
>Wally:
You may want to consider adjusting your lathe height. You may have a safety issue with something loose and hazardous coming too close to the spindle.
Ouch.
