>I have a few turned pieces that cry out for some embellishment. I want to try my hand at this piercing that I see (and admire) being done. Can you use a dental handpiece with an ordinary compressor? Two hole or four? What kind of burrs? Thank you all for any help , you guys are great.
>I use my regular shop compressor. You'll also need a controller to give you the pressure that's recommended by whatever brand of dental tool you have. I buy my carbide tipped burrs from Binh Pho.
In order to successfully use a dental burr you need to turn your bowl/vessel to 1/16th in. sidewalls.
>Greg I don't do very much piercing so a high speed tool isn't an option for me right now. I use a dremel and LOTS of patience. There are two truths to piercing. The thinner the wood the easier it is to pierce and the higher the speed of the cutter the less it follows the grain so piercing is again easier.
As Wally said 1/16" wall thickness and 400,000 rpm cutters make life a lot easier. Dremels run at 26,000 but uses electricity. My small air grinder runs at 56,000 but is an air hog, my compressor runs constantly. The Dental grinders run at 400,000 and use less air. They are great but run around $350.
>Greg, It's a big help when piercing if you take the time to drill a hole to start the piercing bit in.I drill a hole about the size of the burr I am using,usually about 1/16 is big enough. That way you dont have to plunge the burr into the wood and risk burning the bit or the wood.Usually I just drill random holes all over the area I'm going to work on,placement isnt critical as you will remove most of the wood anyway.....take your time and dont rush it....have fun....
>Where have you seen them for $350, John? The ones I saw were 3 or 4 times that! Not that I would ever be able to get to a consistent 1/16" wall thickness so I could use one, but I am curious.
>Carole, I bought my dental tool from Binh Pho for about $350 plus $75 for a controller. It's the same tool that Binh uses. I bought it from him at the AAW bash in Portland last summer. He sells burrs for it for $2.50 apiece. I've found that I've used 1 or perhaps 2 burrs for each of the pieces that I've done. He has a DVD out with some good instructions. I recommend it.
I also recommend as very good reading, the book "River of Destiny". It's about the life and work of Binh.
Re: Getting a consistant 1/16 wall thickness trick
Al Crandall -NW of Indy-
>Carole, get a small drill with a drill stop on it and set the stop to drill a depth just a hair over 1/16". Drill random holes in the turning before starting to hollow. When your "dimples" become through holes, you are at the desired 1/16" thickness.
Barbara Gill, Remlik VA
>I know you are talking about a really small bit. Even so won't you see the holes when you put the finish on (oil)? Also, the holes will allow the finish to weep back to the surface so if you are not diligent about wiping the piece and checking it a number of times, you will end up with shiny dots all over.
I have heard of this technique before but never bothered to ask the question.
>Barbara I think they are talking about piercing so you basically do some piercing where the drill holes appear. This eliminates them. I know Terry Daniels used to drill holes to judge the thickness and I think he said that the sawdust filled them back in. I never tried this. I have enough bug holes already. :)
>I bought an NSK Presto from a company in Miami for $269.00 They still have them at $289.00 on EBay. Dentall drill bits can be purchased on EBay for less than $1.00 each. The thinner the better when piercing but I seldom get to Wallys thickness , it just takes longer when thicker. I never predrill holes for a random pattern. I sometimes sketch a design if I want a precise pattern. The most important thing is not to rush it.
>It helps to have a friendly relation with your dentist, they only use their burrs once and toss them, carbide, diamonds and differient profiles. The diamonds clean up real good on the white stone you usually get with your turbine. The dentist puts mine in some sort of cleaner to kill any germs before he gives them to me so I don't sweat getting someones crud. I paid up tp $3.50 a diamond burr and some of the carbides were even higher. What ever you carve on wood, eggs or metal wear a dust mask, the dust is so fine you hardly know your breathing it until later. Have a good time doing it,amazing to watch your piece evolve in front of your eyes and it seems you can't stop, you have to finish it. Don't rush, relax, enjoy, not everyone has the patience to sit for hours doing that, its a labor of love and each piece will be a little differient even if you use the same pattern.
>To turn consistant 1/6th inch sidewalls on a vessel you need good calipers and as you approach the desired thickness you need to measure very frequently. I've turned a lot of thin walled vessels and I'll admit that I lose one once in a while. Part of turning thin is using sound. Well, I know the sound that I hear just before going through the side
Fingers make poor calipers. You'll even get a different reading with your left hand than you will with your right hand. Try it.
