I have a "multi-use" boring bar...
steve antonucci
>I started out with an Ellsworth style boring bar. It was a piece of 5/8" cold rolled from Home Depot. David CA glues his cutters, but I decided to tap a set screw into mine in case I needed to remove the cutter.
Last year, I watched Andre Martel cut with a hook tool, and decided to give one a try. At $40 a pop, I figured it would be worth the shot to try to make one first from some scrap before I went nuts and bought one. Here's what I did:
The hole in my boring bar is set up for a 1/4" cutter, so I took a 1/4" O1 cut-off I had laying round. Holding it in vise grips, I heat the end to a bright orange glow with a MAPP torch (1-2 min.). With the biggest hammer you own, flatten about 3/4" inch to 1/16"-1/8" thick. Cool it with lots of water.
I use a belt sander to flatten the two sides of the hammered area. Use an old belt. Don't worry about bluing the steel, since it's going back under the torch. I also grind the primary bevel on the INSIDE or righthand side of the flat. Cool with water again.
If you have a metal vise (also my anvil), hold the bit in the vise. Reheat the flat to glowing. Using the vise grips, bend a hook of your liking. Mine are U to C shaped. With the metal still glowing, remove from vise with vise grips and quench in oil to harden. I use mineral oil in a metal container because it's clear and I can see the hook. Do this outside, and let the oil cool if you are making "lots" of these or you risk a fire. One hook won't be a problem.
When it is sufficiently cool, I clean off the scale with a little brass brush and sharpen with a Dremel and a cone shaped stone. I hone with a diamond file inside and out. The things cut like mad in end grain.
I've attached a picture of the first one I made. I've made a few since, and each one gets a little better...
Steven
