Have a question? Ask Woody!
Tailstock swing away
don lewonczyk
>Anyone know the guy in GA that makes the taistock swing away attachments for the powermatic3520b? I wrote it down at the last turners meeting but can't find it now. It runs for something over $200. This rebate is burning a hole in my pocket and I need these new toys, I ain't had afix in 3 months and its killing me, at least maybe I'll get some tools from Doug Thompson on Saturday or Monday, that should do it for a day or two. Thanks for the help. DonL
Re: Tailstock swing away
Harvey Meyer in Atlanta
>Don Butler is who you want. You can find it at www.butlerturning.com
I was looking at it last weekend at SSS. If you have a bed extension, you would probably have to drill and tap holes to mount it - no big deal. Seems like a well built device for the job at hand. For bowl turning at the end of the bed, it seems like it would work fine. Also, several folks told me it's in the way when you hollow. I can see how it would interfere with any of the captured rig systems and some hand-held hollowing tools. Depends on the size of the piece and the angle of attack. To me, it looks like it would be in the way when hollowing.
Harvey
don lewonczyk
>Thank you guys, exactly what I was looking for. I scratched my head looking for the paper that I wrote his name and phone number on and was still lost, I have to strike while the irons hot. Right now I have her half way talked into stuff I need to make me feel better, boy is that wearing thin!!!!! DonL
Here are a bunch of alternatives *LINK*
Jerry Hall
>including a swing-away and down that I have used successfully this year. Could be built of metal instead of wood. Shop built and commercial.
http://docs.google.com/View?docID=d4b7vjd_31hpg89x
Dick Hines
Dick Hines
>Do those swing away things get into the way of holowing rigs? I turn form the end of my lathe a lot and I have wondered if this caused a problem.
Bob Macgregor
>I think I saw an ad for one near the back of the most recent Woodturning Design. I don't know if it is the same fellow, though, since I don't have the magazine with me.
Dick Hines
Dick Hines
>All of ideas are good but it seems to that the tail stock will still get into your way when useing a captured hollowing rig.
Until I can't lift the tail stock anymore I think I will just pull it off and sit in the floor out of the way.
>I personally think the swing away tailstocks would still be in the way, at least for the way that I turn. I like being able to slide it onto a table and then roll it out of the way. What I did for a friend of mine was hang a barn door slide above the lathe and then mounted a small block and tackle like you use to hang deer on the barn door slide. Then all she has to do is hook the block and tackle up to the tailstock and slide it back out of the way. She usually moves it back to a workbench that sits to the side of the lathe and lowers it onto that.
Hollowing
Jerry Hall
>I don't use a hollowing rig, but do of course hollow from the end and need to work with the tool handle far to the right. That is why I made my "Swing-away" also "swing down" so the tail center is then below center, and when latched to the right side of the bed, live center removed, it is nearly always out of the way. I built mine out of wood as a prototype, fully intending to weld one up later. But it has held up fine, gate hinge and all. Does require a little muscling in the transition to the bed, but no big deal.
Re: Hollowing
Randy G
>Any Picks of this setup Jerry, I'd like to see something like that?
Steven Antonucci
I'm with you.
steve antonucci
>I'm not sure which lathe has the heaviest tailstock(70#?), but my Nova is a one-hander. Seems to me the best place is out of the way (like on top of my tablesaw...:-)
Steven
Swing away and down Pictures *LINK*
Jerry Hall
>is in link attached, Randy. The whole approach could be more refined, and I planned to do a better, more rigid, job with a welded up solution, but so far this is a bit like the energizer bunny and it just keeps on working.
Swing Away Construction Pictures
Re: Swing away and down Pictures
>Jerry Several years ago I saw a homemade version on the end of a Oneway lathe. A short bed section was mounted on a short round piece of pipe about the size of the oneway bed. This was mounted on another pipe that so the whole thing would swivel over 90 degrees to leave the tailstock out of the way. I thought it would not be hard to put a hinge on this so it would also swing sideways to get it away from the end. That way I could use my Powermatic off the end and still not have the tailstock in the way.
