Last turning for a while
Craig Daymon
>A friend is getting married in June and I promised them a platter. I managed to get it turned before the lathe is taken by its new owner. It is 19.75" in diameter, turned from 2.5" thick stock. It started out about 1/4 inch over 20", fitting between the bed ways on (formerly) my 3520. Turning went pretty well, but I had a very little end grain tear on the inside curve. The biggest problem was making the mistake of power sanding. The softer, partly spalted area sanded away much quicker than the rest causing some undulation in an otherwise very flat pan.
Anyway, here's the pics.
-Craig
Re: Last turning for a while
Back side
Craig Daymon
>There is a little button ring in the middle. This also serves to support the platter in the center if it is put into service. It is just a hair smaller in height that the outer base bead.
-Craig
Edge...and finishing question
Craig Daymon
>The edge tapers inward to a large bead at the edge of the dish. It is about 1.25" wide. I'm planning to burn some commemorative message in this area for the eventual owners. The edge tapers on the underside as well, getting slightly thicker as it approaches the dish.
-Craig
P.S. I'm thinking of a couple coats of Watco's followed by thinned poly. I know Watco's really is a poly, but I wanted the outer coat to be a little tougher. Any thoughts? (NOTE: Wood hardener was applied to the blank before turning and for that reason...and the spalting...I want to make sure it is sealed.) Thanks.
Randy G
>Very nice looking platter... They should love it
Allen Neighbors
>I'd say that you did well on it. It'll be an heirloom platter.
So, when does the new lathe arrive...
Steven Kubien
>...and what did you get?
Just curious
Steve Kubien
Re: So, when does the new lathe arrive...
Craig Daymon
>More a question of when does the new house get built. I'm moving to Indianapolis and am trying to sell all the large shop items. After I get settled and get the Pennsylvania house sold, I'll look into building a new house/shop. Still have a tablesaw to sell.
Then I'll get a 3520B (or C?) since all my accessories will work with it and I really loved the 3520A. Might add a bed extension, but I'll have other things that may take priority.
Still tons to do to get ready to move.
-Craig
