Newbie turning plane knobs
Tom MacGregor
>I picked up a used Jet mini-lathe dirt cheap & managed to successfully turn some handles for three old garage sale socket chisels. This looks like it could be way too much fun - as if I don't have enough projects going on already! Does anyone have any tips or tricks I should know about to try turning some plane knobs out of well seasoned rosewood? I plan to practice first on some sugar maple - not too difficult to come by in Vermont.
Re: Newbie turning plane knobs
>Oh no, Tom, you are ruined now. Turning is so much fun that this should be called the Turning Addiction forum.
The only "trick" is practice! A little practice with a detail/spindle gouge should let you make some beautiful plane knobs. Rosewood turns like a charm - cuts smoothly often doesn't need much sanding.
If you don't have one, a good book to get started is either Richard Raffan's "Turning Wood" or Mike Darlow's "Fundamentals of Woodturning". Both explain the tools, the cuts, and give exercises guaranteed to lead to expertise quickly.
When turning a knob, an important thing is deciding how to hold the work. If you don't have one, a 4-jawed chuck like the Supernova is probably the most useful accessory. I turn things like knobs, finger tops, "weed" pots, and bottle stoppers by gripping a piece of wood firmly in a chuck. If it needs a hole in one end, I turn a flat surface on the end and drill the hole using either a drill chuck mounted on the tailstock or with a drill bit held by hand or with a pair of vice grips. (If by hand, you have to get it started exactly in the center.) Then turn, part off, and finish the very top by hand. The photo shows a bottle stopper turned and about ready to part off.
There is a better way that allows you to completely turn and finish the top as well as the bottom but it needs one more mounting device. Mount in the chuck and drill as before, turn and finish the bottom and most of the shape, then use a parting tool to cut to length. Turn the knob around and mount it again gripping it by the hole. This can be done with a home-made "pin" chuck, a screw chuck of the right size, or a piece of threaded rod held in a drill chuck mounted in the headstock. I've even read of people jamming the object back onto a drill bit held in the headstock but I haven't had much success with that with hard wood. I suppose jamming in on a wooden dowel might work. Once the knob is properly secured, finish turn the outside and the top.
Dick Hines
Dick Hines
>Take a piece of wood longer than the knob you want to turn. Turn it so it is a tight fit in the spindle hole tap it in the hole. Drill a hole smaller than the screw/bolt you will be useing for the knob. Turn your knob and part it off. Sand the top and you are good to go.
This can be easier if you have a chuck to hole the blank
Steven Antonucci
Along the lines of what John said...
steve antonucci
>If I had a drill chuck, I'd drill out the center hole and the recess for the nut that holds the knob on the plane. I'd then take a screw or bolt that was properly sized and chuck it in the drill chuck in the headstock and hand tighten a nut on to hold it.
Your best option is to make a pinchuck, since you can flip the work end for end and have full access to top and bottom. If you search the archives, there have been numerous posts about making them.
Good luck and post a picture of the final results...
Steven
Tom, an important caution!!
Allen Neighbors
>When turning Rosewood, if you don't have a good dust collector and a respirator-mask, make sure you have enough air flow that it carries the dust away from you and outside. Rosewood makes some toxic dust.
I got a bad lung and sinus infection that lasted over 6 weeks from turning and sanding without taking proper precautions.
Just in case you weren't aware of it... :)
Steven Kubien
>My only suggestion is to start taking pictures of your flat work tools. You will need pictures once you start selling them off to pay for more turning gear.
Welcome to the vortex
Steve Kubien
Dominic Greco in Richboro PA
>Hi Tom,
I'm a current hand tool fanatic and wood turner and I've made several knobs for my hand tools as well and found an easy method to make one. If you plan on making more than one, a mandrel is a good thing to use. You can use a pen making mandrel. They're relatively cheap and can be purchased at PSI or CSUSA. The shaft on most of the mandrels is just under 1/4", so any blank that has a 1/4" dia hole drilled in it should fit. Traced the outline of your current knob on some paper, glue it to some hardboard and cut the template out. Use a caliper to measure the various diameters of the knob and write them down on your template. This will help you to duplicate the shape.
I would start with piece of junk wood. Nothing too soft, like pine. I would use poplar or oak if you can get it.
Good luck!
Dominic
An article showing how to turn knobs *LINK*
>Here is an article I found that shows the method I was talking about for turning knobs.
There also is a number of articles on that site for making new totes for your planes as well.
Turning Plane Knobs
See ya around,
Dominic
Turning Plane Knobs
