Re: Help With Threads (all I know about it, long)
Al Crandall -NW of Indy-
>Questions: Do you make a box with a friction fit lid and go from there?
No, you make the hole in the "nut" one thread pitch smaller than the "bolt". My jig uses 8 threads per inch pitch so I turn an interference fit of 1/8" between the two pieces. If your jig uses 16 tpi or 20 tpi, then you would use 1/16 or 1/20 inch smaller hole than bolt.
Do you thread the inside of the lid first, then the tenon on the base?
I thread mostly urns so there is a huge difference between the mass of the urn and the mass of the lid. I choose to cut the lid threads first so that I'm fussing with a smaller piece as I try to mate those freshly cut threads with the partially cut threads of the urn.
Which side of the lid/base should the cutter be on? The near side (operator side)or the far side?
It depends upon the design of your jig. My jig won't let me put the cutter on the back side of the jig centerline. All cutting is done on the front half of the jig. I can cut male threads in excess of 7" diameter. Female threads are limited on the small side by the cutter diameter, and on the large side by the male plug which gazinta it.
How thick should the tenon on the base be to start? I tried to thread one but got the tenon too thin to start so that didn't work.
Decide first how many threads you want when done, multiply by the thread pitch of your jig, add at least half the thickness of your cutter. This is minimum tenon length.
How do you keep the same depth for the inside threads (lid) and the tenon on the base?
First of all, the male threads can be on either the lid or the box, and so it follows that the female threads can also be on either the lid or the box. I cut female threads into the opening of my urns and put the "tenon" on the lid. This maximizes the volume of the urn while not compromizing the shape I want. As for keeping the same depth, it is not a critical dimension. It's wood after all. Start with the proper relationship between the male and female pieces, cut the first set of threads so that they don't quite make a sharp thread on the surface you started with, and then cut the second piece. Make multiple cuts until things fit like you want them to fit. Take a close look at any thread around you. The little flat on the exposed edge of the thread is there so that it can't get down into the sharp corner of the thread it mates to. No difference on male or female.
I notice that the cutter cuts really sharp threads. Should these be blunted a little with sandpaper?
I just covered this above. Don't cut your threads so deep that the top of the thread is sharp. Leave a little flat.
Anything else I should know?
God yes! You have to chamfer the leading edge of the male and the opening of the female threads before you take the pieces off the lathe and head to the threading jig. How much chamfer? More than the depth of the threads you will cut. What angle chamfer? More than the 30* which is on one side of your thread cutter. Why the chamfer? Because without it, there will be an area next to the spot where the jig completes the first full rotation (the first full thread) which has a lump of wood with a flat on it much wider than any of the flats you are leaving on top of the thread points. It will neither allow a properly formed male thread to pass by it, nor will it start into a properly formed female thread. If the female thread is going to fit all the way against a shoulder at the back end of the male, you will need to undercut the male at the shoulder and chamfer it like the leading edge was chamfered. Same reason as already given. There can be no flat on the top of the male threads which is wider than any place else on the threads. If the female threads are blind, there must be one full thread more than on the male, or else you will have the same condition at the back end which I just covered with the male threads which chased against a shoulder. Again the fix is an undercut and chamfer. This is another reason I choose to cut the female threads in the body of the urns. This way they are not blind or limited in depth and any length tenon on the lid will screw into them. It is also easy to go back and trim for grain alignment. Design critera will most often dictate where the male and female cuts are made.
If your threads fit nicely together, but bind up before fully engaged, you have a problem at the back end of either the male or female. You probably didn't undercut deep enough or the chamfer at the back end was the wrong angle and didn't remove enough wood. If the first time the pieces go together the fit is sloppy, then you probably left a lump of wood at the beginning of the cut which has a wider flat on top than the rest of the threads, or else you cut the second set of threads too aggressively and went past the thread depth you wanted. Sneak up on the proper fit when cutting the second set of threads in a mating pair.
